chrisg
posted on 18/8/07 at 03:05 PM |
rocking arm pivots
Just looking at some rocking arms for a new suspension set-up.
What sort of bushes would you recommend for the pivots?
In my mind I've got something like metro radius arm bushes or a similar OE manufacturers bush, Polyurethane bushes or taper roller bearings.
Any thoughts on the pro's and con's, or any other suggestions?
cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Cousin Cleotis
posted on 18/8/07 at 03:11 PM |
1980's Nissan Lemans sports prototypes used 5/8" sperical bearings, they were using something like 2000lb springs, with loads of
downforce.
Paul
[Edited on 18/8/07 by Cousin Cleotis]
chrisg
posted on 18/8/07 at 03:17 PM |
Interesting.
Presumably the joints were placed vertically with the pivot running between 2 or 3 joints?
Doug68
posted on 18/8/07 at 03:28 PM |
Before throwing out the whole rocking arm idea as a waste off effort, I looked at this quite a lot. Basically as the shock to wheel movement ratio
will inevitably be reduced any movement in worn or compliant bushes is amplified.
So as a result it looks to me to be necessary to go to metal or possibly nylon bushes of some sort so as to eradicate the compliance issues.
I've not actually worked on one of these systems first hand so this is from my research and calcs.
People who've actually built cars with this system may have a different view...
v8kid
posted on 18/8/07 at 04:50 PM |
My riot uses standard mettalastic bushes as per the book. The motion ratio is 1:1 and the compressability of the bushes is low- I would have thought
much stiffer than the stiffness of the springs and I admit I don't see Dougs point for a non aero car.
Having said that racing Strikers which use the same system of top rocking arms use taper roller bearings I presume it is to reduce stiction in the
bearing rather than a compliance issue.
There are a couple of sites showing the system try Googling Striker
C10CoryM
posted on 18/8/07 at 04:58 PM |
What it comes down to is that there is no perfect option for this application. Rubber will add a spring to the rocker which reduces the shock/springs
efficiency. Solid bushings will wear, and bearings will brinell from the shock loads.
Im going to start out with some good wide needle bearings and see what happens. Assuming I ever get that far
"Our watchword evermore shall be: The Maple Leaf Forever!"
MikeR
posted on 18/8/07 at 05:02 PM |
didn't one car use mini rear radius arm thingys.
errm, radius arm bush? you know the large thing that bolts onto the sub frame and the rear suspension arm.
(ok, i know thats a terrible description, just back from watching the mighty wigan althetic play a great game of footy, we're top of the league
and my brains stopped working)
posted on 18/8/07 at 05:11 PM |
Do you mean Lotus 33 style rocking arms ? They look good and have aerodynamic advantages but when you start looking are the structural issues they
become a little less attractive.
If I were doing it I would use the needle rollers and pivot pin from either BL Mini or an old Jag rear suspension.
Or if its is a rising rate rocker set as per current single seater practice some guys on the forum have tread that road already, some are truly
excellent some less successful, again a lot of structural issues involved but at least it by-passes the problem of wishbone flexing.
[Edited on 18/8/07 by britishtrident]
C10CoryM
posted on 18/8/07 at 05:16 PM |
Yes, I guess I assumed you were talking about push/pull rod rockers and not a rocking upper a-arm. Which are you using?
Im using a pushrod setup because of how wide my front track is. There is no viable way to mount the coilover to both the control arm and frame.
v8kid
posted on 18/8/07 at 05:28 PM |
Found this on the Fisher sports Car site
"Fit the rocker arm first, this pivots on an M12 x 225 bolt, using tube ferrule and nylon tophat section bushes. These bushes will be a tight
fit in the rocker arms, the tube ferrule must be 0.5mm longer than the bushed arm and must be able to move freely. If the ferrule is too tight in the
nylon, ream out with an old bolt slotted and fitted onto a drill with emery cloth. Some resistance is acceptable – too loose and you will have slack
suspension!"
To get good mechanical grip from the suspension I have 300lb springs on the front (40/60 f/r weight) and I just went out to the garage and jumped up
and down on the car. Rocker arms moved a lot but I coulden't see any deflection in the metalastic bushes.
chrisg
posted on 18/8/07 at 05:41 PM |
Formula 27 mate, that's where i got the idea from!!
And yes we're talking about "Lotus 33 style top rocking arms.
anyone know the diameter of the mini/metro bushes?
cheers
Chris
Tralfaz
posted on 18/8/07 at 05:58 PM |
Sealed needle bearings
posted on 18/8/07 at 06:44 PM |
Not off the top of my head sorry. However, there is a cheap set of radius arm repair kits on
eBay
you might be interested in.
Note that the mini radius arm setup has a bronze bearing on one side and a needle roller on the other for some reason. They last very well if they
are regularly greased, but owners almost never bother so they have a bit of a reputation for wearing.
chrisg
posted on 18/8/07 at 06:51 PM |
I think I might go for needle bearings, the car is very light in weight and you wouldn't get any "sticktion" with those.
cheers
Chris
v8kid
posted on 19/8/07 at 06:39 AM |
Chris,
Let us know how you get on with sourcing bearings the arguement has convinced me to change to roller bearings. I disconnected the springs and there is
quite a bit of resistance to movement through the metalastic bushes and as you say with a light car, the riot has only 100kg on the front wheels, it
may well be noticable on the road. There is a bonus that the caster would be dead easy to adjust.
posted on 19/8/07 at 09:21 AM |
Chris , I think the formula27 used Metro radius arm repair kits rather than Mini ones . The Mini ones only have one needle roller bearing, the other
end uses a bush that needs reaming to size
chrisg
posted on 19/8/07 at 03:04 PM |
I'll let you know and Rusty - yes you're right I've just looked out my old F27 plans and they are the Metro bushes.
Chris
Liam
posted on 22/8/07 at 04:46 PM |
I'm using poly bushes on my setup. A friend of mine who's building a menace (mid engined fury) was told by fisher that they switched from
bushes to needle roller bearings in their pivots, but then switched back to bushes as people complained the ride was too harsh with the bearings. I
expect racers would use bearings though.
Liam
chrisg
posted on 22/8/07 at 10:21 PM |
That's interesting.
I wouldn't have thought that the pivots would have had any bearing(geddit!) on the ride quality.
I mean one end up the other end down via the coilspring/damper, if the pivot is having an effect on ride quality wouldn' t that mean that the
bush was flexing?
And if it is, is that a bad thing?
Shouldn't ride compromises be taken out in the spring/damper?
I've been regarding the pivot as purely that - a fixed point.
I'll look in to it!
Chris
posted on 23/8/07 at 07:31 AM |
Using metallic bearings will effect harshness and noise transmission but much less on ride quality.
JB
posted on 23/8/07 at 04:38 PM |
Rocker Arm pivots
These are the bearings I used. They mainly take radial load but also except a small amount of lateral, I cant remember the exact terminoligy of the
bearings.
I used Loctite 638 to hold them into the housings.
Remember that the pivot sees twice the force compared to one end.....
John
PS Just found this on my website....
I chose NJ type cylindrical roller bearings. They give the major load rating in the radial direction with a small amount in the axial direction.
[Edited on 23/8/07 by JB]
[Edited on 25/8/07 by JB]
Liam
posted on 23/8/07 at 06:29 PM |
Using metal bearings on the pivot is just the same as using rose joints on conventional wishbones - i.e. will give a teeth shaking ride. Your
'vibration path' would be upright=>ball joint=>wishbone=>bearing=>chassis - in other words rigid all the way to the chassis
with no rubber/poly in the way.
Liam
procomp
posted on 23/8/07 at 07:18 PM |
Hi sorry i forgot all about this discusion and the other related one.
In the other post i refered to problems accuring with the setup. This comment was aimed at the issue of the pivots and all the asosiated problems.
At the end of the day the only way ST got it to work better was to use needlle roller bearings.
But the big problem is the loads placed into the chassis. and how you go about sorting that without ending up with a chassis that needs replacing
every time you give the wheel a knock.
I had typed a long post detailing all the problems that the various manufacturers have had with this setup. But i think it would of just upset to many
people.
But one thing to remember is that if going with the rocker arm setup is that you will also require your dampers to be valved to suit that application
IE not off the shelf items. But Have any of the manufactureres done that and supply them with there kits ?.
cheers matt
marc n
posted on 23/8/07 at 07:55 PM |
most bearing dealers / stockists should be able to help, with regards load ratings suitability etc
on our rockers we run 2 cassete needle roller bearings inboard and and two needle radial thrusts outboard per rocker,
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
Angel Acevedo
posted on 23/8/07 at 11:12 PM |
best regards
marc
That may not be so locost...
