big_wasa
posted on 28/8/07 at 09:10 PM |
Down link question ?
Made my down link today The ends are push fit, 45mm into a piece of 3mm wall tube . Fully welded.
Question I was going to cross drill it and put in some 4mm roll pins as an extra piece of mind.
Is this a good idea? or have you got a better one
[Edited on 28/8/07 by big_wasa]
posted on 28/8/07 at 11:44 PM |
Do you trust your welding?
Welded works fine. Drill a hole in it and weaken it I think is my theory.
locoboy
posted on 29/8/07 at 08:31 AM |
If you feel you must, maybe drill a hole either side through the outer only and plug weld it.
Locoboy
James
posted on 29/8/07 at 09:24 AM |
At someone's suggestion years ago I cut the end of the extension at 45°. This meant there was a much larger welded area.
It hasn't failed yet..... fingers crossed!
- Muhammad Ali
big_wasa
posted on 29/8/07 at 02:28 PM |
Ta,
I cut the ends of the tube at 45 deg and plug welded as an extra.
JB
posted on 29/8/07 at 06:34 PM |
Welding with 45 degree ends is an excellent idea.
However because I worry a lot, I drill and put 2 pins in (at 90 degree to each other) and then braze the whole lot together. I worry about the
embrittlement with welding and cracking on the heat effected zone. I know the chances of it happening are very remote but when there is another method
that improves I use it.
