oadamo
posted on 7/9/07 at 11:55 AM |
type 9 bellhousing
hi all can you get a alloy type9 bell housing from a production car or are they after market items.
adam
JAG
posted on 7/9/07 at 12:18 PM |
I THINK the Escort MkII RS2000 had an alloy bell housing but I could well be wrong!
Justin
mookaloid
posted on 7/9/07 at 12:44 PM |
like
th
is?
You'd be better looking for one with a clutch fork though as I believe they might be different to the standard one. I had to mod mine to fit.
Mark
John Bonnett
posted on 7/9/07 at 12:47 PM |
This is something I'm interested in too.
I am using an RS2000 alloy bellhousing between a two litre four speed box and the Pinto. This bellhousing is normally used with the alloy sump that
has the arrangement for the clutch although I have a steel sump with the clutch cable passing through a machined plate screwed in place. The alloy
housing is more bulky than the cast iron one and may give clearance problems.
I'm considering changing to a Type 9 and wonder if anyone can tell me if the bellhousing will screw onto this box.
Many thanks in advance
John
Chris_G
posted on 7/9/07 at 01:55 PM |
John
Yes, an RS2000 alloy bellhousing will bolt to a type 9 box.
I have recently bought one to replace my cast iron one next time the engine is out.
See HERE for some more info (NTDWM)....
Chris
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
Chris_G
posted on 7/9/07 at 01:58 PM |
Just had a thought.....
One thing that you might need to check is the resulting gearstick position as the 4 speedeer and the type 9 may not be the same length???
Chris
Rudy
posted on 7/9/07 at 04:10 PM |
quote: Originally posted by mookaloid
like
th
is?
Mark
Or this : http://www.rallydesign.co.uk/catalog/default.php
I do not know if it fit but you can ask rally design
Sorry about my English
John Bonnett
posted on 7/9/07 at 06:17 PM |
Many thanks Chris, that's good to know.
I'd better go and talk to Brian Hill now.
John
