Author: Subject: Wheel Bearings
h2o
posted on 11/9/07 at 09:29 AM Reply With Quote
Wheel Bearings
Anyone know where I can buy just the oil seals for the rear hub carriers. I have removed my hub from the drive shafts and found they are corroded and split, so I was going to buy new ones, but the bearings and races look ok, however my local motor factors only do a kit with the lot in.
andyps
posted on 11/9/07 at 12:38 PM Reply With Quote
Try a bearing distributor - look in Yellow Pages. If there is one near you BRT Bearings are most likely to know the part number for a car application, others will be able to get the part number if you have dimensions.
John Bonnett
posted on 11/9/07 at 04:25 PM Reply With Quote
No that's a high vacuum specialist!!
