Author: Subject: Spotted something interesting - anti-vibration washer
posted on 13/9/07 at 09:05 AM Reply With Quote
not seen these before:
from RS, M3 to M20
Nordlock® Anti-vibration Washers
are designed to prevent the loosening of bolted assemblies due to vibration.
Used in pairs, their operation depends on surface cam angles which are greater than the thread helix angle of the bolts with which they are used.
* Suitable for use at all vibrational frequencies and amplitudes, with shock or static loads
* Unaffected by temperatures or lubricants
Re-usable
* Can be used with all HT bolts up to 12.9 grade
* Yellow zinc chromated steel finish
Fatgadget
posted on 13/9/07 at 09:30 AM Reply With Quote
Check out the video. http://www.nord-lock.com/default.asp?url=51.16.37
RazMan
posted on 13/9/07 at 09:32 AM Reply With Quote
I have seen these before and apparently they really do work.
Raz
Avoneer
posted on 13/9/07 at 11:04 AM Reply With Quote
Yeah, that vid is cool.
But where can you buy them and hoe dear are they?
Pat...
Fatgadget
posted on 13/9/07 at 11:40 AM Reply With Quote
NORD-LOCK Ltd.
Office 4a, Aspire Business Centre
Ordnance Road, Tidworth WILTS, SP9 7QD
Tel: + 44 (0)198 084 7129
Fax: + 44 (0)198 084 7674
Email: enquiries@nord-lock.co.uk
Website: www.nord-lock.co.uk
NS Dev
posted on 13/9/07 at 11:56 AM Reply With Quote
They are great, and do work very well.
Normal spring washers are more touble than they are worth, usually breaking and probably cause more loose bolts than they prevent.
norlock washers on the other hand are brill!
posted on 13/9/07 at 01:19 PM Reply With Quote
Originally posted by Avoneer
But where can you buy them and how dear are they?
RS sell them, box of 50, so presumabley 25 pairs.
M3 9.49
M4 9.55
M5 9.55
M6 10.25
M8 10.85
M10 14.29
+ VAT.
(about 20 p each )
MikeR
posted on 13/9/07 at 01:31 PM Reply With Quote
watched the vid - that is cool.
donut
posted on 13/9/07 at 02:34 PM Reply With Quote
Had some on my Indy and yes they are superb.
locoboy
posted on 13/9/07 at 03:14 PM Reply With Quote
One of my Curtain sided trailers at work has them on as wheel nuts.
Locoboy
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 14/9/07 at 04:19 PM Reply With Quote
So True........
Normal spring washers are awful. I have been removing them from my old cars for years and will not fit them.
thomas4age
posted on 16/9/07 at 12:57 AM Reply With Quote
Been using those for years, I have a brother that's working in a large machinery construction company and alwas provides lunchboxes full of bolts washers and nordlock rings....
grtz Thomas
PS when using M10 with nordlich don't be surprized if the spanner brakes clean in half these are really really tight!
If Lucas made guns, Wars wouldn't start either.
