Author: Subject: Propshaft too short by literally an inch or 2?? (Type 9 Box - Sierra Diff)
mattgriffiths2002
posted on 17/9/07 at 01:24 PM Reply With Quote
Hi guys,
I have a standard size locost propshaft fitted between a type 9 box and a Sierra LSD but after fitting my transmission I have found that it is literally a couple of inches too short. I think I could do with a sandwich plate of about an inch or 2 thickness between the diff and the propshaft but does anyone know where I can get this from or if there is anything else I could do to solve this problem?
Has anyone else had this problem too?
Thanks for your help,
Matt
posted on 17/9/07 at 01:34 PM Reply With Quote
Do you have any option to move the engine and gearbox further back in the car?
Fatgadget
posted on 17/9/07 at 02:10 PM Reply With Quote
^^^ Well worth persevering down that route.It's a hassle but the benefits far outweigh the grief involved.
posted on 17/9/07 at 02:11 PM Reply With Quote
Don't forget that you don't want the propshaft fully home into the gearbox - you should leave it about 1" out.
(But you may well know that already... )
snapper
posted on 17/9/07 at 03:07 PM Reply With Quote
Could be a chance to fit the V6 box with the Caterham 30mm spacer then you only have to move the gearbox mount
I eat to survive
I drink to forget
novacaine
posted on 17/9/07 at 06:09 PM Reply With Quote
i think you should cut the chassis in half and remove 1 to 2 inches from it, weld it back together find that the propshaft is still too short and then slap yourself for not measuring the gap between the prop and the diff.
or something like that
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
mattgriffiths2002
posted on 17/9/07 at 06:52 PM Reply With Quote
Thanks for your suggestions,
The box is as far back as it will go really so that isnt really an option. The shaft is probably sticking out 2 or 3 inches with about 1 or 2 inches in the box.
I think I might go for the spacer option between the shaft and the diff but does anyone know where I can get something like that from?
Matt
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 18/9/07 at 06:30 PM Reply With Quote
Props
Do the job properly and get the prop lengthened.
OR advertise the prop and sell it to someone on here who needs one that length and then get a new one made.
John Bonnett
posted on 18/9/07 at 06:57 PM Reply With Quote
I just wondered how your prop fits compared with the one in the Phoenix which works fine.
mattgriffiths2002
posted on 18/9/07 at 07:18 PM Reply With Quote
Yeh my set up looks similar to that and the propshaft looks exactly the same. I dont think my gearbox goes back as far as that though and I am struggling to make it as any further back would mean it hitting the bulkhead.
Matt
jonnyprop
posted on 2/10/07 at 11:09 AM Reply With Quote
Why don't you have your propshaft lengthened? Or alternatively have a new one built with geaseable circlip UJ's, recomended if you still have the original Ford staked/crimped in UJ's.
Dunning & Fairbank can do this for you but need to know the distance from the gearbox oil seal to the diff flange face.
check out www.propshafts.co.uk
