jabbahutt
posted on 20/9/07 at 02:19 PM |
best/easy place to start
Afternoon all
Well this will probably be the first of many posts on the subject of wiring. It's a vick Green loom, 2.0 pinto MK indy.
The loom is in and engine connections all made. Headlight/indicator wiring fitted to roughly the right part of the car ready for connection.
I'm looking at the mess under the scuttle and wondering where the hell to start. I've got the 3 ignition wires connected and thats it.
Tonight going to try and identify all wires that won't be used such as washers etc and bundle them out of the way to see if that makes things
easier to follow.
Any advice as to the best method to avoid confusion etc. It doesn't help that the column area/relay part of the wiring diagram is the least
clear of the whole thing, are the things that look like cubes with 9 circles in connector blocks? and are the flasher/hazard relays on the diagram.
Any advice as to best order to do things much appreciated.
Nigel
speedyxjs
posted on 20/9/07 at 02:42 PM |
I think the only way unfortunately is to just start and sort them one by one. it will get easier the more you do
nib1980
posted on 20/9/07 at 03:01 PM |
Yep Basically what He said! its the only way I did it. wiring took abaout 3 full days, but I like things like that so no problem really
posted on 20/9/07 at 05:03 PM |
I personally (though my wife says I'm rather strange ) like wrapping a little bit of masking tape round each wire end (to leave a little tab)
and then write on that what the cable is for. You can do this for all the loom then do all the connecting and wiring /crimping/soldering in one go
without having to look at the loom / wiring diagram again (or as much)... Any wires which aren't being used you can lay down along the loom and
wrap a little bit of insulting tape around the very end. Keeps it out of the way and if you ever want to use that wire it'll be identifiable by
its tab and pulling it out of the insulating tape will be easy....
It also makes it easier to work out what goes where if you ever have to work on the wiring again and everything is labelled.
twybrow
posted on 20/9/07 at 05:22 PM |
Ben that is exactly what I did. The only downside is they tend to stick to each other. I also grouped together wires I knew were supposed to be
together, and cable tied. That way you have less to route seperately and easier to identify.
jkarran
posted on 21/9/07 at 10:00 AM |
That's what I did too when I made my loom, label with the tape. Label every wire, group into bundles that run to each item/area using tape or
cable ties then do the connectors and terminals in one multi-day soldering session.
You'll still end up in a tangle but that's half the fun of it... apparently.
jk
