Author: Subject: Do i have enough length!!! :D
FlansS14
posted on 1/10/07 at 03:04 PM Reply With Quote
On the front of my Luego i have cortina uprights with the classis maxi balljoints and transit draglink tops m18 iirc. But i have massive camber and if i unscrew them im worried there will not be enough threads in the arm... here's a pic of the camber and where the thread goes to at the moment (to my finger nail)
http://s13.photobucket.com/albums/a282/FlansS14/?action=view&current=30092007233.jpg
http://s13.photobucket.com/albums/a282/FlansS14/?action=view&current=30092007234.jpg
also where can i get some safty nuts in that thread
Why didn't i just make it simple!
VinceGledhill
posted on 1/10/07 at 03:09 PM Reply With Quote
Why not unscrew it until you have about 1mm of camber and then check how much you have in there. Then make a judgement?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
jollygreengiant
posted on 1/10/07 at 03:27 PM Reply With Quote
Lock nuts were normally supplied with the arms. Failing that a good nut & bolt stockist would have them.
jack trolley
posted on 1/10/07 at 03:41 PM Reply With Quote
Are you sure the wishbones are suitable for Cortina uprights?
They might be designed for Sierra uprights?
mistergrumpy
posted on 1/10/07 at 03:57 PM Reply With Quote
Yeah classic. I had it the other way. Cortina bones and Sierra upright. It looks like you have Sierra width bones and Cortina upright.
Paul (Notts)
posted on 1/10/07 at 04:43 PM Reply With Quote
which luego chassis are you using ?
the velocity xt uses sierra uprights..
not sure about the locost chassis wishbones
Paul
posted on 1/10/07 at 05:01 PM Reply With Quote
My Luego Locost uses Cortina uprights . IIRC Lolocost sell the lock nuts. If the end of the thread is level with your thumb in the second piccie I would have thought you have enough thread to adjust safely . Adjust it and recheck!
[Edited on 1/10/07 by rusty nuts]
Paul (Notts)
posted on 1/10/07 at 05:27 PM Reply With Quote
looks like a velocity to me....
Me thinks sierra wishbones!!!!!
FlansS14
posted on 1/10/07 at 07:39 PM Reply With Quote
Its a Luego Velocity with Locost GRP and i did spec Cortina Uprights when ordering... i hope they got it right There exactly the same length as the rears if that makes a difference. It just looks like there will only be an inch left in the arm if i wind it out which i would have thought would be unsafe with heavy breaking. hmmmmmmmmmm now im worried. lol
Mal
posted on 1/10/07 at 07:43 PM Reply With Quote
Thread Engagement
A safe minimum of thread engagement would be 1.25x the thread diameter. This would be 1.25x18 = 22.5mm.
Mal
FlansS14
posted on 1/10/07 at 07:46 PM Reply With Quote
wow that sounds very little. not sure i'd be happy with that breaking hard from 150mph+ lo maybe ill adjust and double check
posted on 1/10/07 at 10:13 PM Reply With Quote
Mal
That's the rule of thumb for a bolt used for clamping, but in this instance the further the balljoint is wound out the higher the bending moment being applied to the rather stressed section of thread between the threaded tube and locknut. I'd certainly want the TRE screwed in as far as possible.
