Author: Subject: Will indicators pass?????
RobH
posted on 10/10/07 at 08:41 PM Reply With Quote
I have bought these indictors but I’m not sure if they will pass SVA because there is no sign of an “E” mark on the lens, and the radius on the rear of the body seems a bit small.
The very well known and reputable company I bought them from said, “they are fine for SVA”, but I have read that all the lights must have an “E” mark on the lens. The last thing I want is to fit them only to have them fail.
Has anyone out there fitted these indicators and had them pass or fail.
Thanks Rob
caber
posted on 10/10/07 at 08:51 PM Reply With Quote
I hope these will pass its what I have on mine, I'll be able to tell you in a few weeks!
Caber
RazMan
posted on 10/10/07 at 08:57 PM Reply With Quote
You don't neccessarily need an E mark on them to pass SVA as long as they are deemed as 'suitable' by Mr SVA.
Raz
JohnN
posted on 10/10/07 at 09:17 PM Reply With Quote
I had some smaller ones, SVA weren't bothered about the lack of E marking, but pronounced them too dim and suggested I'd probably find they didn't have any reflectors inside (which they didn't). Fitted some salvaged from a torch and they were then deemed OK.
caber
posted on 10/10/07 at 11:14 PM Reply With Quote
Mine don't have reflectors I guess something else to make!
Caber
mookaloid
posted on 10/10/07 at 11:48 PM Reply With Quote
Tin foil?
Locost solution
marshall
posted on 11/10/07 at 05:44 AM Reply With Quote
hi i used them on my tiger Avon an they passed ok. i did not have to mke them longer in any way.just put them on have a look in my photo Archive there might be a picture in there. good luck on the day....
RobH
posted on 11/10/07 at 07:03 PM Reply With Quote
Thanks for the replys guys.
I think I will go for it and just fit them.
Rob
Steve @ sVc
posted on 26/10/07 at 12:51 PM Reply With Quote
Yes Rob, if fitted in-line with the SVA, ie no more inwards than 400 mm from the widest part of the car (this may be the rear wheels).
They have been supplied to both builders and kit makers for a few years and never had a fail reported to us.
You could have phoned us you know!
Regards
Steve @ sVc
saigonij
posted on 26/10/07 at 01:43 PM Reply With Quote
im using Landrover ones, and they dont have reflectors on the inside either....
is this a common problem / something to look out for?
Steve @ sVc
posted on 29/10/07 at 01:14 PM Reply With Quote
Souldn't be a problem. Caterham - Westfield etc etc,l use these "Land Rover" type indicator lights. They are not fitted with a reflector
Regards
Steve @ sVc
