waterrat
posted on 21/10/07 at 01:12 PM |
wishbone positioning
i'm wondering if the wishbones should be mounted parallel to each other or if there is a set angle for best performance. i'm sorry if
i'm flogging the same old dead horse with this question but my searches either through up to many postings or when i refined my search there was
little of interest.
posted on 21/10/07 at 01:34 PM |
Search under anti-dive
Really just adds problems in a small light low car.
In a full size Jag or Merc it is a different matter in that situation a tiny bit of anti-dive helps.
t.j.
posted on 21/10/07 at 08:46 PM |
side view: Mine are standing at 5,5 degr "DIVE" both upper and lower wishbone
All Avon's have also dive instead of anti-dive.
Can't tell you now how it behaves, my car isn't finished yet.
Maybe someone wiser??
Front view: not parrallel but "roll-centre and camber, bump-steer etc.
Upper view: parrallel as i don't know what all will happen, scary .....
[Edited on 21/10/07 by t.j.]
[Edited on 22/10/07 by t.j.]
posted on 22/10/07 at 08:08 AM |
In what plane? e.g. parallel as viewed from the front of the car, or parallel as viewed from the side of the car?
posted on 22/10/07 at 09:14 AM |
The mounts on the chassis are parallel to each other but the top wishbone slopes up to the top balljoint in Locost chassis. Some kits are parallel in
both planes though so the wheels stay in the same plane instead off adding camber when the body rolls.
t.j.
posted on 22/10/07 at 01:09 PM |
put my visual-plane to it
waterrat
posted on 22/10/07 at 07:46 PM |
when i say parralle i'm talking about the arms of the wishbone viewed from the front.
posted on 22/10/07 at 11:14 PM |
Have you got a copy of the build yourself a sportscar book. The measurements in there work fine for the height setting with Cortina uprights. Look
through people's photo archives and you will see that the top wishbone slopes up to the top balljoint so is not parallel to the bottom one.
posted on 23/10/07 at 08:39 AM |
Then no, they should not be parallel if you are building a book locost.
waterrat
posted on 23/10/07 at 06:18 PM |
would someone please post the measurments for wishbone possitioning as well as the distance of the top and bottom balljoint location lugs on the
cortina uprights. just in case the mazda rx7 has a diffrent dimention.
many thanks.
t.j.
posted on 23/10/07 at 07:59 PM |
I had to search but hey i knew someone send me.........
http://locostbuilders.co.uk/viewthread.php?tid=67118
