martin1973
posted on 24/10/07 at 12:40 PM |
propshaft
i'm trying to remove the uj from 1 end but no circlips got somekind of ring with grips in?
is it threaded?
how do you remove it?
martin
posted on 24/10/07 at 01:06 PM |
Some UJs are not easily rebuildable as the bearing is retained by deforming the yoke around the bearing with a press. This often looks like a series
of "dashes" in a ring.
martin1973
posted on 24/10/07 at 01:26 PM |
are bugger
oh well i'll see if i can chisel it out??
cheers martin
martin
JB
posted on 24/10/07 at 05:31 PM |
Staked Uj`s
You can remove the UJ with a hammer and vice. Chances are the ends of the caps will break off. We would then gas axe (engineering term for gas
cutting) the cross and tap the caps out with a punch.
You need a special tool to refit a UJ. I have never seen one done successfully without........
leave it to the professionals
posted on 25/10/07 at 08:10 AM |
quote: Originally posted by JB
Staked
That's the word I was looking for. Got a memory like one of those kitchen things with holes in...
[Edited on 25/10/07 by MikeRJ]
