<<  1    2  >>
New Topic New Reply
Author: Subject: Plastic end caps for square tube?
posted on 25/9/03 at 11:27 AM Reply With Quote
Does anyone know where I can get some of those plastic end caps that push fit into 25x25mm square tube steel?
TIA
Nick
MK Goldrush
posted on 25/9/03 at 11:29 AM Reply With Quote
MK Engineering.
AvonBelgium
posted on 25/9/03 at 11:35 AM Reply With Quote
Normally you can find these in a general hardware store, these are used in general furniture constructions
posted on 25/9/03 at 12:21 PM Reply With Quote
Are they water tight enough to be used on external ones? i was gonna post about end caps soon...
cant find the bit in the book, so i was gonna use 16gauge plates over the ends.
posted on 25/9/03 at 01:51 PM Reply With Quote
I was going to 'stick' them in using some silicone sealant to make sure they are watertight.
My MK chassis only needs 2 caps, so I reckon the hardware stores worth a look.
Nick
spy
posted on 25/9/03 at 10:18 PM Reply With Quote
The end caps come in sizes suitable for light gauge and heavy gauge tubing. It's the light gauge stuff you need. You may be able to get them from the same place where you bought your tubing from.
posted on 26/9/03 at 07:22 AM Reply With Quote
That'll be MK then!
I'm having a look through RS/Farnell at work to see if I can order some on the sly.
Nick
Simon
posted on 29/9/03 at 08:42 AM Reply With Quote
Weld the holes up
Stronger than plastic and waterproof
Simon
ned
posted on 29/9/03 at 09:37 AM Reply With Quote
I welded mine up last week, easy job and is going to be better than a plastic thingy (IMHO) my pics will be updated soon...
Ned.
beware, I've got yellow skin
posted on 29/9/03 at 01:26 PM Reply With Quote
Not up for welding me!
Plus chassis is already painted with the floor riveted on next to the hole I want to fill.
Nick
Ben_Copeland
posted on 30/9/03 at 08:36 PM Reply With Quote
i've used them........
Silicon Seal them in!
ned
posted on 1/10/03 at 08:58 AM Reply With Quote
Nick,
I'm kind of suprised they aren't supplied welded by MK....
Ned.
Ben_Copeland
posted on 1/10/03 at 04:03 PM Reply With Quote
Probably couldn't be bothered to do them
The Shootist
posted on 1/10/03 at 05:02 PM Reply With Quote
Not Silicone....
Don't use silicone unless it is the type approved for use on electronics. Regular silicone uses a corrosive ingredient (Vinegar) that can cause the tubes to rust.
I would suggest a metal cube (Aluminum) cut to fit tightly and epoxy (JB Weld if you can get it) in place. A hard insert will give better rigidity than a soft plug.
An old trick from aircraft construction (tube & fabric) is to drill the tubes at the joints so all the tubes are inter-connected with all but one tube capped, then a small amount of boiled linseed oil is poured into the frame, and the last opening sealed up. The linseed oil will coat the interior of the frame tubes giving a fair level of corrosion resistance.
[Edited on 1/10/03 by The Shootist]
blueshift
posted on 1/10/03 at 05:26 PM Reply With Quote
how does the oil get around to coat all the tubes?
Ben_Copeland
posted on 1/10/03 at 05:34 PM Reply With Quote
probably turn it over and over in different directions lol
GO
posted on 1/10/03 at 05:49 PM Reply With Quote
maybe cos its boiling, so the linseed oil steam will coat the inner surfaces??
posted on 2/10/03 at 07:50 AM Reply With Quote
Lots of good ideas guys, but I think a plastic cap and some PU sealant that I used for the floor will suffice.
Nick
Ben_Copeland
posted on 2/10/03 at 08:32 AM Reply With Quote
thats what i did.
DaveFJ
posted on 2/10/03 at 08:44 AM Reply With Quote
do not put aluminium blocks into steel tubes - never heard of dissimilair metal corrosion ?
[Edited on 2/10/03 by protofj]
Ben_Copeland
posted on 2/10/03 at 08:48 AM Reply With Quote
yeh, if your going to make u something in metal... use steel and weld it in, i did this most places.... some places just have plastic plugs
DaveFJ
posted on 3/11/03 at 01:34 PM Reply With Quote
Nick
Did you ever find a supplier for your plastic end caps ?
If so how much did they put you back ?
I'v just been checking out RS components and they are offering them @ about £6 for 12 plus vat and delivery....
posted on 4/11/03 at 03:38 AM Reply With Quote
Plastic Bungs
I'd be surprised if MK forgot to put them in...
... IMHO, most people tend to forget to take them out before they send the chassis to be plastic coated and they burn up!
Regarding oil, steel is porous and it will eventually seep through the section, causing the caoting to fall off!
DaveFJ
posted on 4/11/03 at 08:59 AM Reply With Quote
Talked to MK yetserday and they cannot supply them......
givemethebighammer
posted on 4/11/03 at 10:10 PM Reply With Quote
Nick, I think I have a bag of the said 25mm x 25mm plugs somewhere in the garage. Bought them from a guy who puts together warehouse shelving.
How many do you need, drop me your address on U2U and I send them at the weekend if I can find them.
<<  1    2  >>
New Topic New Reply
