Author: Subject: Electronic shifters
pathfinder
posted on 5/11/07 at 12:50 PM Reply With Quote
Electronic shifters
As you are probably aware I have been working with electronic shifters for the last 8 months or so.
Here is what I have come up with and a few prices:
Electronic shift kit complete with everything needed to install onto bike engine and engine kill module (similar kits don’t include the kill module). £480
Steering wheel mounted push buttons, cut to your design (you supply the DXF) in aluminium by waterjet (carbon fibre and cad work will incur extra charge). £55
Quick release electrical connector for removable steering wheels. £30
Steering wheel mounted flappy paddles. £180
All prices include P&P
Best Regards
Thom
[Edited on 5/11/07 by pathfinder] Rescued attachment 137325-1.jpg
pathfinder
posted on 5/11/07 at 12:51 PM Reply With Quote
pathfinder
posted on 5/11/07 at 12:52 PM Reply With Quote
Guinness
posted on 5/11/07 at 12:58 PM Reply With Quote
Fantastic Pathfinder!
Just what I'm looking for following Saturdays blat.
Just a quick couple of questions if I may?
Does the engine kill work with carb'd engines? Does it allow flat upshifts and downshifts? I run a cable operated shift at the moment, would the soleniod have to be mounted at the engine end or could it be mounted at the lever end in the tunnel?
Any discount for an early adopter?
Mike
dan__wright
posted on 5/11/07 at 01:15 PM Reply With Quote
damned you! more money i will be spending shortly lol
does look very nice! is neutral just a very quick dab of the button?
also, do the wheel mounted paddles clear sierra stalks?
[Edited on 5/11/07 by dan__wright]
FREE THE ROADSTER ONE…!!
gezer
posted on 5/11/07 at 02:28 PM Reply With Quote
another question probably daft i know but do you still need the clutch pedal to put it into !st gear first as most of the commercial designs do ???
I'm to old to live and to young to die --- buggerit
dan__wright
posted on 5/11/07 at 04:54 PM Reply With Quote
yep you still need clutch for idling / puling away and probably downshifting too.
jono_misfit
posted on 5/11/07 at 05:54 PM Reply With Quote
How smart is the controller?
Does it read gear position and do re-shifts?
Jono
pathfinder
posted on 5/11/07 at 06:00 PM Reply With Quote
Hi
Guinness:
Yes it will work with carb’d engines, basically all your doing is cutting the power to the coils for a split second, (the control module is adjustable) to allow flat up and down shifts, in theory you should be able to do flat down shifts but I recon a bit of clutch would be sensible.
The solenoid is a bit of a beast and I recon you would be able to mount it in the tunnel and shift your existing linkage (unless it is stupidly heavy).
dan__wright:
yes neutral is a quick dab on the paddle, however I would always recommend keeping a manual alternative just in case. It should clear the stalks but obviously it depends how big your steering wheel and hub are!
Jono:
No it doesn’t read gear position or do re-shifts
Chris7
posted on 28/4/08 at 09:00 AM Reply With Quote
Electronic Shift Kit
Hi
Guys
Has anybody got any contact details for pathfinder the guy who is making the electronic shift kits
Thanks Chris
posted on 28/4/08 at 11:21 AM Reply With Quote
Chris, you have U2U.
Phil
Jon Ison
posted on 28/4/08 at 12:00 PM Reply With Quote
N also, any price for a kit with no ignition cut ?
Chris7
posted on 28/4/08 at 01:00 PM Reply With Quote
Paddles Ordered
Thanks Phil
New shiny bits
on Order
Thanks Chris
charlierevell
posted on 16/7/08 at 06:31 PM Reply With Quote
How did these paddles go then? Im unsure wether to look at this as and option or cable op.
How do you run the wires to the paddles on a non removable wheel??
Tango orange is an 'IN' colour!!
charlierevell
posted on 16/7/08 at 09:22 PM Reply With Quote
That was useful! haha
I meant instead of the wired boss, but i've seen those coiled leads now and guess its those.
Anyone else using this system? How are you gettin on with it?
charlierevell
posted on 18/7/08 at 01:12 PM Reply With Quote
Hmmmm..... i have a sierra boss which is quite wide and i'm running a 270mm wheel. I'm not sure the paddles will fit! Bugger must look at that!
Pathfinder... you out there?
