Author: Subject: 07 R1 gauges work with 05 R1?
Blackbird
posted on 8/11/07 at 06:11 AM Reply With Quote
Title says it all, I just got a 2005 R1 motor for my locost with no gauges.
I prefer the looks of the 07 R1 gauges over the 04-06, but if it isn't a direct plug-in than I'll stick to the 04-06.
Thanx!
Moti
Ares
posted on 8/11/07 at 12:50 PM Reply With Quote
If the faces look different then I'd be 99% sure the plug would be different.
A u2u to 'yorkshire-engines' should put you straight.
Lack of will power has caused more failure than lack of intelligence or ability.
There's hope yet then !
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 8/11/07 at 06:09 PM Reply With Quote
more importantly the ecus are different so they might not work even if the plugs are right. the r1 dash can be used to change a fair few things on the ecu so its unlikely to work
Blackbird
posted on 9/11/07 at 04:29 PM Reply With Quote
Thanx guys.
Moti
