New Topic New Reply
Author: Subject: Removing carbon deposits
Johnmor
posted on 8/11/07 at 06:11 PM Reply With Quote
Anybody know the best way to remove carbon deposits from an alloy cyinder head.
Don't want to blast it, casting is to complicated.
Any houshold chemicals that may work??
takumi
posted on 8/11/07 at 06:34 PM Reply With Quote
Any acidic or caustic solution (Cilit Bang ?)will lift the carbon off, but if left a moment too long it will oxidise the surface and leave a dull grey finish. If you do try it, make sure if you have a bucket of soapy water to dunk it into, best add some bi-carbonate of soda to the water to help neutralise the cleaning acid/alkali .
I find a strong solvent like toluene/petrol left or a while loosens it quite nicely. Best find a big air tight plastic box to put it in and seal the lid. -something like an underbed storage box..?
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
posted on 8/11/07 at 06:47 PM Reply With Quote
Caustic solutions on alloy isn't a good idea.
I am pretty sure Cillit Bang is acidic rather than caustic.
Traditional way is scrape it off by hand or a wire brush in an electric drill.
These days nylon brushes are available.
ned
posted on 8/11/07 at 08:00 PM Reply With Quote
a friend of mine makes up a mixture of petrol, household detergent of some sort and something else that he sprays on, leaves to work in briefly and then cleans up with a stiff brush and rag.
Ned.
beware, I've got yellow skin
Danozeman
posted on 8/11/07 at 08:30 PM Reply With Quote
diesel and petrol mix works well. Or even diesel on its own left to soak then wire brush off.
Dan
posted on 8/11/07 at 08:50 PM Reply With Quote
Wire brushes and petroleum spirit - ouch
gezer
posted on 8/11/07 at 10:22 PM Reply With Quote
would oven cleaner work ????
okay i admit no SWMBO
I'm to old to live and to young to die --- buggerit
gezer
posted on 8/11/07 at 10:24 PM Reply With Quote
CIF is the best i've found, and not to bad on the pinkies
posted on 12/11/07 at 08:22 PM Reply With Quote
Gasket stripper works in minutes .
New Topic New Reply
