davepro
posted on 16/11/07 at 09:51 PM |
Cortina Front Hubs
Hi Guys
I am currently rebuilding a pair of Cortina front uprights and hubs. I am fitting new bearings and this is where I need some advise.
I have brought 2 sets of bearings and each set consists of 2 bearings, one large and one small and a oil seal which fits on the inside of the hub,
there is no oil seal for the out side, is this correct?
Thanks in advance.
Dave
rayward
posted on 16/11/07 at 10:17 PM |
yes,
should be cap which fits outside, and is normally packed with grease
Ray
RazMan
posted on 16/11/07 at 10:18 PM |
The outside just has a cap that fits tightly over the nut & split pin
Raz
posted on 17/11/07 at 10:19 AM |
Remember to allow some clearance when you adjust the bearing.
