Author: Subject: Jacking your seven (no it's not a early 90's dance)
orbital
posted on 18/11/07 at 06:07 PM Reply With Quote
Hi All,
I know this sounds like daft question but how do you all jack up your cars? I've just borrowed my brother-in-laws trolley jack and it wont go under the chassis The saddle on the jack is about 135mm high at it's lowest point and the chassis is about 105-110mm. I don't really want to spend a fortune on a low profile jack. Anyone got any ideas?
graememk
posted on 18/11/07 at 06:10 PM Reply With Quote
i drive mine onto some bricks, then put the jack under
indykid
drive the car onto 2 bits of wood or flags or whatever you have to hand that's more than 30mm thick..........
far cheaper than a low saddle jack
tom
posted on 18/11/07 at 06:13 PM Reply With Quote
i use a normal budget jack (like the one that comes with your donor) to lift the first inch, then stick a trolley jack under it.
mark chandler
posted on 18/11/07 at 06:35 PM Reply With Quote
6 foot of 4" x 2" wood for me, shove it under the front or back and heave it onto axle stands....
jos
posted on 18/11/07 at 06:51 PM Reply With Quote
jack it up under where the suspension connects to the lower suspension arms
zxrlocost
posted on 18/11/07 at 06:57 PM Reply With Quote
I dont think you could get more lower than my fireblade car
and a normal wind up jack goes under with something to spread the load if be then whack some axle stands under
RichieW
posted on 18/11/07 at 07:00 PM Reply With Quote
Scissor jacks are very low. Try to get one of those if you can. Not very fashionable these days so you may have to try a car boot or something to get one.
[Edited on 18/11/07 by RichieW]
orbital
posted on 18/11/07 at 08:18 PM Reply With Quote
I think I might have a scissor jack somewhere, if not then I'll got on a brick hunt Cheers all!
Dave
[Edited on 18/11/07 by orbital]
DavidM
posted on 18/11/07 at 09:17 PM Reply With Quote
I use one of those cheap trolley jacks that Machine Mart and others sell. Just fits under mine.
caber
posted on 18/11/07 at 09:38 PM Reply With Quote
Unbolted the rotating bit of the saddle on my cheap old trolley jack, just goes under now
Caber
Asterix
posted on 18/11/07 at 09:59 PM Reply With Quote
Clarkes race jack have a min cradle of 73mm...recommended, if you can be arsed to keep securing the allen key done head bolts
From machine mart about 80
[Edited on 18/11/07 by Asterix]
Aint 53.78/ Cadw 96.39/ Crof 97/ CurbL1 37.01/ CurbL2 81.? wet/ Heth 82.34 kaput/ Loto tba/ Shel 41.4 wet/ Thor 56.36/ Tycr 129.52
Sponsors... Pets Testing Webhosting
RazMan
posted on 18/11/07 at 11:09 PM Reply With Quote
Cheap Halfrauds 2 ton trolley jack - I removed the swivelly thing and replaced it with a hard rubber pad. It now goes down plenty low enough.
Raz
blueshift
posted on 18/11/07 at 11:16 PM Reply With Quote
On my road car when a jack is a tight fit I can usually shove the car a couple of cm higher with my shoulder to get it under. When it comes back down again friction in the suspension is working for you and it usually sits back down high enough to slide the jack out.
stevebubs
posted on 19/11/07 at 02:03 AM Reply With Quote
The only way I could get my fraud's trolley jack under my mate's 350Z was by raising it up a couple of inches first with the scissor jack out of the boot.
