deanwilson
| posted on 28/11/07 at 09:16 AM |
adapter plate
how do you make your own adapter plate for transmissions
mark chandler
| posted on 28/11/07 at 09:40 AM |
Weld the two bell housing together with care f they are ali
Here's mine, Rover V8 onto Audi box
Its then sorting out the clutch.
stevec
| posted on 28/11/07 at 09:52 AM |
Here is my effort, Getrag front gear casing to Type 9. Ignore the flowers
Steve.
Picture linky
snapper
| posted on 28/11/07 at 01:10 PM |
Mark if you put that in the 7 where will you sit?
I eat to survive
I drink to forget
deanwilson
| posted on 28/11/07 at 04:33 PM |
what about the spigot bearing and the shaft wouldent the shaft not sit in the spigot bearing if i added an inch on to the bel housing some thing like
that
mark chandler
| posted on 28/11/07 at 07:07 PM |
In front of it !
You need to have a measure up, this method used to be used to fit fiat twin cams into escorts years ago.
I am using the audi flywheel bolted to a rangerover flex plate
[Edited on 28/11/07 by mark chandler]
