New Topic New Reply
Author: Subject: trailer idea design
GeoffB
posted on 2/12/07 at 10:05 PM Reply With Quote
trailer idea design
i got the basic from a bloke who built one for his fire fox and just adapted it for my indy and my garage..
I have only worked out the real basic but i need feed back good or bad please..??
[img]http://[/img]
jos
posted on 2/12/07 at 10:10 PM Reply With Quote
it aint going anywhere wothout any wheels - an axle (or pair of) would probably help too
What about ramps and storage
oadamo
posted on 2/12/07 at 10:12 PM Reply With Quote
you will have 1-1.5 meter hanging off the back where the main beams are it will bend with the car on.
adam
oadamo
posted on 2/12/07 at 10:20 PM Reply With Quote
if i was gonna make one i would use 125x50x6 channel. like this with some 5mm chequer running down each side for the car to run on. you could put some braces between the rails. you would have to solid mounting points for the wheels each side. and fully weld it.
adam
GeoffB
posted on 2/12/07 at 10:23 PM Reply With Quote
ramps will slide in between rear decks and bolt to rear brace and brace (postion to be determined)..
im have a indyblade weighing about 450kgs on it..
maybe some additional bracing or a rear
a frame..?
I was looking at bolting it all togeather so it can be dismantled in the winter months
[Edited on 2/12/07 by GeoffB]
oadamo
posted on 2/12/07 at 10:34 PM Reply With Quote
Originally posted by oadamo
if your going to do that you will need a return on the foled section but i dont think it will last. but its up to you. if your braces meet this line where your angle is you will still have a bend point
adam
wilkingj
posted on 3/12/07 at 08:30 AM Reply With Quote
Is that 105 or 10.5 degrees at the back of the hitch?
Best Regards
Geoff
http://www.v8viento.co.uk
GeoffB
posted on 3/12/07 at 12:07 PM Reply With Quote
Its 105 (one hundred and five) degrees..i got this figure from the bolt holes on a coupling on the bradley website..i struggled to work this out and think this is ok.. but being a total amauter at this i not sure..
All the feedback is most welcome..if we can design and test a basic design and it works we could all use it and adapt where nessacary..Sound Famailer..?????
here what im aiming for
http://www.davebence.co.uk/onyx_firefox/trailer_project.htm
[Edited on 3/12/07 by GeoffB]
New Topic New Reply
