cloudy
posted on 3/12/07 at 12:53 PM |
Loosing weight from sierra rearend?
There are plenty of options available to lighten up the front end - alloy uprights, alloy hubs etc.
Are there any common ways of dropping some weight off the sierra rear setup? The obvious candidates would be turning some material off the hubs and
having the bearing+caliper mount made from ally?
James
Jamse
[Edited on 3/12/07 by cloudy]
RickRick
posted on 3/12/07 at 01:03 PM |
swap the brake calipers for something lighter?
Richard Quinn
posted on 3/12/07 at 01:43 PM |
Geoff Berrisford does alloy Sierra bearing carriers. Freelander diff with these, some one piece driveshafts and some lighter brakes might make some
difference.
muzchap
posted on 3/12/07 at 02:03 PM |
Why would you want to lighten the rear end?
It's hard enough to get decent usuable power down as it is, without making it any lighter? Especially in 'damp' conditions. The
issue has always been keeping the back end grippy with front engine, rear drive scenarios - Capri's anyone? I sometimes wish I had more weight
in the back...
I'd concentrate on lightening the front and leave the rears - or cheaper still - go on a diet (not aimed at you personally, just a cheaper
'locost' alternative'
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Fatgadget
posted on 3/12/07 at 02:35 PM |
in the back...
A couple of salient points you have made. Hells bells..Ford Capris,notably the first 3 litres!
As for shedding personal weight!..The late great Gerry Marshall throws that one out of the window.
2b_pablo
posted on 3/12/07 at 02:36 PM |
I dont thik the sierra rear end is *that* bad.
there is only the beam and 2 arms and they arent too heavy. the trailing arms are a bit OTT if you arent using springs in the spring pads you could
prob fabricate some nice alloy arms or something.
Minicooper@work
posted on 3/12/07 at 02:43 PM |
I believe this car is mid engined so won't have quite the traction problems of a capri
cloudy
posted on 3/12/07 at 05:52 PM |
indeed, all my weight is over the back end anyway - so anything I can loose here will only help bring the weight distribution towards 50:50
does Geoff Berrisford have a website at all?
t.j.
posted on 3/12/07 at 07:17 PM |
make your own IRS
blueshift
posted on 3/12/07 at 08:54 PM |
Reducing unsprung weight is a good thing for traction, not bad.
muzchap
posted on 3/12/07 at 09:46 PM |
Agreed in a Mid/Rear configuration - didn't realise it was Mid/Rear
Well everything needs to be alloy mate
Just like my Elise - everything is so bloody light, the 4 calipers = 1 Sierra.
I know a guy who's just developed a lightweight rear end kit for kitcars. both sides = the same weight as one of the tradtional hub carriers.
Give me a U2U if interested and I'll hook you up with his details. I wanted to do it - but decided against it as I need the weight or more
pies - pies are cheaper
M
NS Dev
posted on 5/12/07 at 07:52 PM |
GB Engineering linky
next up, reducing weight, first try golf calipers, alloy bodied and fit the std ford sierra rear mounts as well as being cheap.
Next, lighter CV joints, the lobro ones can have a good chunk turned out of them from the od in the middle.
Then the driveshafts can be swapped for lighter ones (from gb engineering) for £80 each
The hubs are not that heavy and certainly the alloy ones are not that much lighter as there's not that much metal there to start with.
The bearings are seriously over the top for a locost etc but your stuck with them really!
