Author: Subject: zetec oil pressure sensor size
les
posted on 4/12/07 at 07:45 PM Reply With Quote
quick question,
I need to replace the original oil pressure sensor, with the sensor for a pressure guage, which (unsuprisingly!) does not fit
so i need to order an adaptor
anyone know what thread size i need to go in the block?
2L zetec
les
posted on 4/12/07 at 10:41 PM Reply With Quote
I left mine alone and plumbed it into the head. That way I get oil pressure in the head and it makes me feel better.
At the cam wheel front of the engine on the inlet side there is a blanking plug. Take that out and you'll find a tapered thread that my Raceline oil pipe screwed straight into.
There is another blank plug behind the coil pack bracket as well. Rescued attachment Oil Pipe.JPG
les
posted on 7/12/07 at 12:03 PM Reply With Quote
fantastic, thanks
what size is your raceline hose fitting?
i have racetech fitting , will that be the same?- slightly nervous of taking out the blanking plug in case the oil pipe does not fit!
les
les
posted on 17/12/07 at 02:14 PM Reply With Quote
hi,
sorry to open this thread again,
can anyone tell me if this is a good place to measure the oil pressure?
for example if the pick up pipe goes dry during cornering will it show the drop?
les
