Author: Subject: Think I just got a bargain
toady
posted on 6/12/07 at 10:13 PM Reply With Quote
As I'm early on with my build, what I use for parts is still quite flexible. I bought a blade engine, only to find out it was a restricted french import, so I've been keeping my eyes open. Just bought a complete 2002 blackkbird engine with rad, oil cooler, downpipes, loom, throttle bodies etc (no ecu) for £560. Blade kit for sale.
posted on 6/12/07 at 10:25 PM Reply With Quote
Are going to dry sump it or take it carefully round corners?
To be honest unless you track-day it a Blackbird engine should be okay..... They do have a tendency for going pop when driven hard on the track though (apparantly oil flow to bearing no 3 is a bit optional)....
russbost
posted on 6/12/07 at 10:39 PM Reply With Quote
Best idea is to take no.3 piston & rod out b4 you start, saves loads of trouble later on!!
posted on 7/12/07 at 09:13 AM Reply With Quote
LOL
Is that what you call preventative maintainance?
posted on 7/12/07 at 11:21 AM Reply With Quote
Use an Accusump on it. Should be ok for road blasting.
Paul TigerB6
posted on 7/12/07 at 12:05 PM Reply With Quote
Here 's one on Fleabay
dan__wright
posted on 7/12/07 at 12:06 PM Reply With Quote
on the blade im pretty sure thers just a loop on two pins for the ecu, cut it and its full power
FREE THE ROADSTER ONE…!!
toady
posted on 8/12/07 at 10:11 AM Reply With Quote
Cheers for the replies. Its only going to be a road car, so do i really need an accusump or baffle.
INDY BIRD
posted on 8/12/07 at 09:46 PM Reply With Quote
Baffle for sure and run 10% more oil should be fine for the road.
Fit oil pressure guage thats visible if you get fluctuations just fit an accusump 4 pint i had no probs on track or road,
Keep the sump as deep as possible and if modifiying it put in some trap doors to stop oil surging in the sump,
Should be ok then,
