Author: Subject: Weatherproof Connectors Help
lsdweb
posted on 26/12/07 at 06:05 PM Reply With Quote
I'm using some weatherproof connectors from Vehicle Wiring (here) but I'm not quite sure how to use them - I'm having problems fitting the red plastic pin-retaining bits on the female terminals - the red plastic bit in the right had section of the photo.
Anybody got any tips or the instructions?!
Regards
Paul (Notts)
posted on 26/12/07 at 06:28 PM Reply With Quote
the red water tight seals are pushed onto the wire first - lagre end first
then crimp the teminal onto the bare end of the wire
then push the terminal into the black plastic holder - look for the littlte locking clip
then push the red water seal down the wire into the black plastic block to seal the wire in.
Paul
ps have had a drink already tonight so hope this makes sense....
not sure which way round the red seals should go so test them first!!
[Edited on 26/12/07 by Paul (Notts)]
macdave69
posted on 26/12/07 at 07:13 PM Reply With Quote
WHS plus they are a real PITA. Only bend the tags, if you bend any other part, they are an ar$e to get right
balidey
posted on 26/12/07 at 08:26 PM Reply With Quote
You can get proper crimps for doing AMP Superseals, but thesea re bloody expensive, so as said above, be very careful and only bend over the tags that grip the wire, there are a couple of other tags that look like they should bend over, but don't, as these are guides. If yuo have bent them over then this may have stoped the red bit going on.
