MK9R
posted on 2/1/08 at 01:09 PM |
ZX9R air filter
Just picked up my 2003 ST Locosaki, its fantastic, but the sausage filter sticking out of the bonnet looks a bit nasty IMO. I went to fit the scopp
that came with the car, but it doesn't fit due to the height of the filter and the backing plate.
I could:-
- Buy a bigger scoop - But what?
- Make a bigger scoop - not really got time
- Replace the filter with induvidual socks - is this an option?/
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
worX
posted on 2/1/08 at 01:10 PM |
It's usually regarded that Socks aren't the best filtration for our cars.
What material is the "cage" of your air filter made from?
Mine is Ali (but some are plastic) and I have managed to squash mine, just slightly, so that it clears my bonnet...
MK9R
posted on 2/1/08 at 01:17 PM |
Its actually the plastic/metal backing plates that causing the biggest foul, i can squash the filter part down enough (foam and metal gauze)
Cheers Austen
RGB car number 9
www.trackace.co.uk
Eggy
posted on 2/1/08 at 01:23 PM |
I'll keep an eye on this subject - I'm currently building a "turbo" style air box (plenium chamber) for my ZX9. I'm not
sure if it's going to work though
worX
posted on 2/1/08 at 01:31 PM |
You can build an airbox as above, but have you tried turning the backing plate so that the tabs are at the lowest point?
I turned mine round and lost about 10mm in height at least...
MK9R
posted on 2/1/08 at 01:33 PM |
Funny you have said that, i've just been thinking that myself
Shame the bonnet has been cut with tabs out for the fixings on the back plate
Cheers Austen
RGB car number 9
www.trackace.co.uk
worX
posted on 2/1/08 at 01:58 PM |
Yes, but your "bump" might actually cover them and fit then though?
Tangerine Scream
posted on 2/1/08 at 06:04 PM |
The ST supplied scoop (from a mitsubishi L200 or something!) fits over a shallow filter.
To give some idea of the area covered by the scoop, look here
linky
Saturday 14th...
I found that the carbs themselves stuck a little over the bonnet line. I originally cut a hole that followed exactly the profile of the required
cut-out. Unfortunately I couldn't remove the bonnet though without a little more widening
I don't actually mind the filter sticking out of the bonnet though
Eggy
posted on 2/1/08 at 07:04 PM |
Steve - have you got any pictures of what you did? I've been playing this evening and can see how you got it to line up............
Ta, Kev.
worX
posted on 3/1/08 at 10:29 AM |
I'll take some in the next day or so and stick em on here...
posted on 3/1/08 at 10:58 AM |
ZX9 airboxes are not symmetrical, you would have to cut and drill it to make it fit upside down.
mistergrumpy
posted on 3/1/08 at 11:10 AM |
^What I was going to say^
worX
posted on 4/1/08 at 12:26 AM |
/\ What I did say! /\
mistergrumpy
posted on 4/1/08 at 10:32 AM |
No no. Don't try and steal the glory its all mine and Petes You never mentioned about cutting and the non symmetry. The glory is all ours.
Hooray!
