Author: Subject: some more pictures of progress.
saigonij
posted on 19/1/08 at 04:38 PM Reply With Quote
a friend on here ( marcus ) sent me a picture yesterday of a westfield inlet plenum to be used with the stock mondeo EFi.
this looked perfect for wat i needed.
i then called westfield yesterday and enquired about it - and they said they knew what i meant and had one in stock, so i ordered it.
lo-and-behold - im in the garage today early in the morning and a parcel force van arrives with my parcel!!!
result!
so i fitted it up ( comes with jub-clips and small section of hose to connect it to the throttlebody ).
works a treat...
and fits perfect
i then made a bracket to mount the airflow meter as follows
the filter will get fresh air from the bonnet scoop and to stop any hot air from the exhaust manifold being sucked in ( or to try and reduce it as much as i can ) i made a heat shield out of some steel sheet from homebase.
im then going to use a 120mm 12v Pc fan and a air duct on the side of the bonnet to help expell hot air..
really please - a really good day today.
onzarob
posted on 19/1/08 at 05:25 PM Reply With Quote
I think the pc fan will be a waste of time. you need to get as much freash air under the bonnet as possible. a PC fan won't be affextive past 5mph at best!!!
You need to seperate the inlet from the engine area. Too keep cool air comming in IMO.
I wouldn't take air from across the engine either, are you trying not to have holes in your bonnet?
BTW...look a very clean build
Rudy
posted on 19/1/08 at 05:27 PM Reply With Quote
wheel done !
But I think pc fan will do nothing .
Sorry about my English
onzarob
posted on 19/1/08 at 05:33 PM Reply With Quote
ah you have a scoop (see link), cool, forget the pc fan though useless
http://www.locostbuilders.co.uk/viewthread.php?tid=81359
Fatboy Dave
posted on 19/1/08 at 05:36 PM Reply With Quote
That looks like the plastic air intake elbow off my mates Pug 306 TD...
Dave
Stop the planet, I want to get off
bassett
posted on 19/1/08 at 06:48 PM Reply With Quote
Looks like a smart setup. How much did it set you back if you dont mind me asking?
zetec
posted on 19/1/08 at 07:18 PM Reply With Quote
Rather than a scoop I would suggest some means of letting hot air out, plenty of air gets in thru the nose but if it has nowhere to go....
Great choice of engine!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
saigonij
posted on 19/1/08 at 10:41 PM Reply With Quote
ok, i think the consensus is to forget the pc fan - i was mainly going to use it to try and get the hot air out when the car is sitting idle in traffic.
The inlet plenum is a fibre glass jobbie from Westfield. It cost me 50ukp, which sounds alot but its saved me a hassle.
the bonnet already has a scoop at the front, and i can see the air filter from out side the car through the scoop.... with the heat sheild over the exhaust manifold this helps keep the under bonnet temp down alot.
thanks for the comments... keep them coming...
