stevec
posted on 30/1/08 at 07:39 PM |
Tyre width
I have a wheel and tyre package at the moment with 15" 6.5J ET38 wheels and 195/50 15 tyres.
Question is what are the widest tyres that will sensibly fit the rims. I am hoping 205's will be OK. More traction needed!!
Thanks.
Steve.
speedyxjs
posted on 30/1/08 at 07:40 PM |
I think 205's should fit. My tintop has 7J's and the tyres are 225
PAUL FISHER
posted on 30/1/08 at 07:50 PM |
No problem,you can put a 205 50 15 on a 6" wide rim,so a 6.5" is ideal
zilspeed
posted on 30/1/08 at 08:11 PM |
Thanks.
Steve.
1) Soften the rear dampers.
2) Fit an LSD
3) Keep the 195s
Traction and handling
[Edited on 30/1/08 by zilspeed]
NeilP
posted on 30/1/08 at 08:19 PM |
Steve,
Got this off one of the tyre manufacturer's website. Neil.
Allowable Rim/Tyre Combinations
6.5 205
7.0 205,215,225
7.5 205,215,225
8.0 215,225,235,245
8.5 225,235,245
9.0 235,245,255
9.5 235,245,255
[Edited on 30/1/2008 by NeilP]
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 30/1/08 at 08:46 PM |
Thanks.
Steve.
2) Fit an LSD
3) Keep the 195s
To the above add check the corner weights.
Often on a light car fitting wide street tyres gives no benefit because the tyres were designed for a much heavier car, the surface of the tread has
to be able to interact with the road surface.
tomblyth
posted on 30/1/08 at 09:00 PM |
and most important is what tyres ?
Try toyo R888
stevec
posted on 30/1/08 at 09:16 PM |
Thanks guys, All comments noted.
Steve.
vxwestie
posted on 1/2/08 at 11:32 PM |
should be fine...
NS Dev
posted on 2/2/08 at 01:51 PM |
agree with zilspeed et al, check everything else first.
I have 380hp per tonne (not sure on your k series turbo power to weight ratio) in my locost and NO traction issues WHATSOEVER, in fact its sometimes
hard to break traction when you want it to!
I run 140lb rear springs i.e. very soft, plus only 2 clicks on the rear protech dampers, plus Yokohama A048R tyres, 195-65 R14
