KenF27
| posted on 3/2/08 at 05:12 PM |
Charade altinator pulley
Does any know where I can get a ribbed pulley wheel to fit onto a Charade altinator. The altinator shaft is approx 13mm dia.
KenF27
| posted on 8/2/08 at 08:56 PM |
Going to the scrappy tomorrow. Any tips on what car has a small alternator like a Charade but with a ribbed pulley wheel.
Schrodinger
| posted on 8/2/08 at 09:09 PM |
Something odd is happening here! I deleted one post and two went
Any way if you have a Lucas Branch near you now LSUK IIRC then they do a catalogue with all of the alternators in it sorted both by application and
model number it also shows the mounting and spindle diameter of each model. Last time I needed one I just took one away, unfortunately I don't
have it to hand to help you with, it's about 600 miles away.
However, ISTR that there are a couple of Swifts that use a similar alternator they will be the 3 cylinder jobies.
Hope this helps
Keith
Aviemore
KenF27
| posted on 8/2/08 at 09:57 PM |
Cheers Keith
