Author: Subject: Sierra Diff cover bolts
eznfrank
posted on 9/2/08 at 05:26 PM Reply With Quote
Is there anything unusual about the Sierra diff cover bolts?? Like them being opposite thread or anything daft like that? Mine aint budged an inch all day!!
I'm a bit loathed to get big bar and big hammer on it just yet, especially with those stoopid star bolt thingies as I imagine it will cost many knuckles!!
piddy
posted on 9/2/08 at 05:51 PM Reply With Quote
They are normal thread, a pig to undo I end up cutting an edge on some and using a chisel.
An impact drive is very useful to undo them.
jacko
posted on 9/2/08 at 06:47 PM Reply With Quote
Give them a smack with a hammer then try again
bigrich
posted on 9/2/08 at 07:54 PM Reply With Quote
+1
give em a whack with the tool of the pikey then undo with a good fitting torx bit
eznfrank
posted on 9/2/08 at 07:59 PM Reply With Quote
Cheers fellas, I'll give it a bash (literally), i did give it a bit of a tickle earlier but was worried about cracking the alloy case, but I guess it'll be reet.
ta
minitici
posted on 9/2/08 at 08:31 PM Reply With Quote
Big hammer and chisel!
But there again I don't re-use the cases after I extract the LSDs
jkarran
posted on 9/2/08 at 11:36 PM Reply With Quote
Impact driver set to '4' resulting in loose bolts and a Dali-esque Torx bit from memory
jk
scotty g
posted on 10/2/08 at 07:11 AM Reply With Quote
i remember all mine were like that as well and i too was a little bit scared to whack it with the large adjuster so i just used a good quality torx bit, with my socket set and a nice long bar, it feels like its not going to go then all of a sudden you hear and feel it go then its lovely and loose.
Good luck anyways.
NS Dev
posted on 10/2/08 at 11:05 AM Reply With Quote
as others said, give them a good clout square on their heads with a hammer before undoing them.
if that fails, try an impact driver if you have one, or on some you can get a sillson round the head of it, and if that fails, smack them undone by tapping them round with a cold chisel
