Author: Subject: Converting 2.0l mk 4 Cortina automatic to a manual
Jayce Lane
posted on 28/10/03 at 01:13 PM Reply With Quote
What I know about engines is a little dangerous, the reason for the post!
I have a 2.0l mk 4 cortina engine and automatic gearbox. I want to convert it to a 5 speed. Will the type 9 work and will the propshaft fit?
Please help on what parts i am going to need to convert, or what should I be looking for?
Thanks guys
ned
posted on 28/10/03 at 01:35 PM Reply With Quote
the type 9 will fit, i've just bought a type9 (for its concentric clutch mechanism) from a guy who had a pinto in a mk1 cortina (conversion). i have the prop if it's of any use? my donor sierra had a type 9 on a 2ltr pinto aswell.
Ned.
beware, I've got yellow skin
timf
posted on 28/10/03 at 01:50 PM Reply With Quote
i think you might have a shock at the postage ned
ned
posted on 28/10/03 at 01:55 PM Reply With Quote
I am happy to take some pics of it, or buyer collects/pays postage
Ned.
posted on 28/10/03 at 03:18 PM Reply With Quote
for the cost of sending it to south africa he could almost buy a ford dealership and start making original parts!
would it just need a normal clutch, bellhousing and box?
chrisg
posted on 28/10/03 at 06:37 PM Reply With Quote
Yep, and a manual flywheel and spigot bearing in it.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
steve m
posted on 28/10/03 at 09:06 PM Reply With Quote
not sure if you will have this problem, but
on a 1600 xflow engine (automatic version) that I was given
all looked good untill i tried to change the flywheel
as, on the automatic version there is no provision for a spigot bearing, as the torque converter bolts to the flywheel
le, no hole for it to to go, so the engine was ok, but I had to swop the crankshaft over with the old engine
theconrodkid
posted on 28/10/03 at 09:22 PM Reply With Quote
steve there should be the hole for the spigot bearing there,sp1,s engine came from an auto
who cares who wins
pass the pork pies
steve m
posted on 28/10/03 at 09:41 PM Reply With Quote
Conrod
Ive still got the crankshaft and I assure you, there is no hole for a spigot bearing,
shall i bring it up to walton bridge on sunday ???
steve
steve m
posted on 28/10/03 at 09:43 PM Reply With Quote
Conrod
our cars look cool at the jaunty angles
steve
Jayce Lane
posted on 29/10/03 at 05:55 AM Reply With Quote
hey Ned
Thanks for the offer on the pics, I would appreciate it. However you could always fly over to South Africa for a holiday and bring the propshaft over as hand luggage.
As mentioned the pics will be helpful as a spigot bearing sounds like some kind of vulgar langauge.
If I can find the hole for the spigot, then I will go ahead, otherwise I will get rid of the engine & gearbox. I wont lose any money on it!
Thanks guys
Cheers JAyce
