Author: Subject: rubber donut
eccsmk
posted on 2/3/08 at 03:39 PM Reply With Quote
rubber donut
where can i get a new rubber donut for my sierra propshaft
thank you
stevec
posted on 2/3/08 at 03:43 PM Reply With Quote
May be try Here
eccsmk
posted on 2/3/08 at 03:51 PM Reply With Quote
thank you your a star
jollygreengiant
posted on 2/3/08 at 05:28 PM Reply With Quote
Most good Motor factors used to keep them. Just DON'T cut the retaining strap till its fitted.
posted on 2/3/08 at 06:20 PM Reply With Quote
Get rid of it, you dont need it. A nice new UJ is better when you shorten your shaft. IMHO of course
2b_pablo
posted on 2/3/08 at 06:29 PM Reply With Quote
please please please bin it and get a shaft with a UJ at each end. mine let go and made a right mess of my transmission tunnel and nearly my leg.
Mine was prob from the donor car but still I hate them. Dont allow for any misalignment in the gearbox->diff which is fine in a production build sierra but in a homemade car its not such a great idea.
all imho of course.
if it aint broke... pull it off and upgrade it!
posted on 2/3/08 at 06:46 PM Reply With Quote
To use the correct name Rotoflex rubber couplings are actually pretty reliable and can cope with more angular movement than a needle roller "Hardy Spicer" Hookes universal joint. But on a Seven type car you don't really have the room required for clearance or the thickness of transmision tunnel to cope with one failing and flailling around..
eccsmk
posted on 2/3/08 at 07:36 PM Reply With Quote
forgot to say this is for another project with a type 9 box in it so would prefer to just replace the rubber
once again thanks folks
