<<  1    2  >>
New Topic New Reply
Author: Subject: tread plate floor
AdamR
posted on 3/3/08 at 12:31 PM Reply With Quote
tread plate floor
I've got some nice ali tread plate to use as my floor. I'm going to bond it with polyurethane adhesive and rivet as is the norm.
The plate is 2mm thick with treads standing perhaps another 2mm proud of the surface. Do I glue and rivet this straight on the same as a flat ali floor (and use enough adhesive to fill up the gap)? Or do I need to grind off the treads along the lines of the chassis tubes so that there is a flush mating surface between the floor and the tubes?
Grinding off the treads would be quite a lot of ballache so I'm hoping I can stick it straight on... just not sure if that will give me a strong enough bond.
TIA
Adam
Mr Whippy
posted on 3/3/08 at 12:36 PM Reply With Quote
what is it patterned on both sides?
andrew-theasby
posted on 3/3/08 at 12:38 PM Reply With Quote
It is a ballache, ive done it, i found 9" grinder with slitting disc best tool for the job, most other things just clog up or melt the alloy. It is obviously the best way to do it, but whether its necessary or not, i wouldnt like to say. I suppose you could shear rivets if there was a gap, but does the chassis really flex that much??
jacko
posted on 3/3/08 at 12:40 PM Reply With Quote
As you say it will be a big job grinding it just sikaflex /tiger sealer / and rivets then put a beed around the inside to finish off
Jacko
RazMan
posted on 3/3/08 at 12:48 PM Reply With Quote
Personally I would grind the mating surface flat to make sure of a good contact area - otherwise you might find that the panel distorts due to the differing gaps when you nip up the rivets
Raz
indykid
posted on 3/3/08 at 01:00 PM Reply With Quote
if you're bothered about the structural rigidity, why are you using chequer plate?
just get plenty of sika on so you don't get any water ingress.
tom
ReMan
posted on 3/3/08 at 01:21 PM Reply With Quote
Cut off enough to fit in the footwell and sell on the rest.Buy a noce smoothe piece for the floor save a load of bother. Fit the pieces into the footwell on top.
matt_claydon
posted on 3/3/08 at 02:04 PM Reply With Quote
The floor adds significant stiffness to the chassis. I would imagine if you don't grind the treads off and have a thick layer of PU a lot of this benefit will be lost.
Someone once told me the diamond discs for grinding stone are good on ali, no experience myslef though so might be bull!
posted on 3/3/08 at 02:08 PM Reply With Quote
Just mark where the chassis will touch and hammer it flat. The sikaflex will then touch 100%
Grinding will remove metal and weaken it off.
AdamR
posted on 3/3/08 at 02:14 PM Reply With Quote
What does that mean? Are you saying that tread plate is generally not as strong as "normal" ali sheet? (Or are you suggesting I should use steel?)
kb58
posted on 3/3/08 at 02:23 PM Reply With Quote
I think that he means that the raised patterns make it impossible (without modification) to be securely fastened. Because of that, much of its strength will be lost.
I agree it's structurally better to use regular aluminum for the floor, reserving smaller pieces of the tread plate for where you want it pretty.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
iank
posted on 3/3/08 at 02:31 PM Reply With Quote
A flap disk will remove the treads quickly and more neatly than a grinding disc (and without risk of a disc exploding due to aluminium contamination - rare but nasty).
Anonymous
Confused but excited.
posted on 3/3/08 at 02:50 PM Reply With Quote
As Ian said, never use grinding discs on soft metals (ali, copper etc), they can explode, with dire consequences.
Flap wheels or power files.
AdamR
posted on 3/3/08 at 02:57 PM Reply With Quote
OK thanks everyone for confirming my thoughts... I've already ordered a stock of flap discs so will get these on to the job.
posted on 3/3/08 at 03:30 PM Reply With Quote
But that is exactly what the whole thread is about?
MikeR
posted on 3/3/08 at 06:25 PM Reply With Quote
daft question - couldn't you silkaflex the panels on and then drill / rivet where the tops of the checker plate touch the chassis?
Surely that is identical to normal riveting ali as you're bonding a touching bit with the chassis + you've got the silkaflex helping hold it on & the added strength of the pattern in the ali plate?
Or have i missed something damned obvious like usual?
leto
posted on 3/3/08 at 06:59 PM Reply With Quote
No you haven't missed anything obvious, it's complexed, hard to explain and the few how know anything on the subject usually stay away from threads like this, because the facts are so uncomfortable you rather not hear them. If you want something that works structurally, welded in a steel floor.
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
AdamR
posted on 3/3/08 at 09:01 PM Reply With Quote
Sounds reasonable to me... the rivets would be fine like that. Just wasn't sure if the PU needs to be squeezed into a thin layer in order to work properly?
ReMan
posted on 3/3/08 at 10:21 PM Reply With Quote
I can't believe you'd go to so much trouble, when theres so little difference in price.
By the time youve worn out your drill and 10 flapwheels you may as well have saved 1/2 a days work, no?
AdamR
posted on 3/3/08 at 10:28 PM Reply With Quote
ReMan, I don't follow... difference in price between what and what?
ReMan
posted on 3/3/08 at 10:35 PM Reply With Quote
2 mm alloy treadplate and 2 mm plain sheet/plate
AdamR
posted on 3/3/08 at 10:45 PM Reply With Quote
Aha. Well I got the sheet of treadplate for next to nothing off of ebay some time ago. Therefore it would get significantly more expensive if I went and bought a plain sheet for the job.
Plus I want the treadplate effect and I don't like the idea of using two bits of metal where one will do.
Plus an hour in the garage wearing out my tools is my idea of fun.
Benonymous
posted on 4/3/08 at 11:30 AM Reply With Quote
Good for you Adam!
MKMike
posted on 4/3/08 at 07:06 PM Reply With Quote
Another couple of points about thread plate is, when the nice shiny surface wears off it looks crap and is hard to clean or shine up again, also it is very hard to get a neat seal around the inside of the car.
Believe me I have had to try to clean sealer off thread plate in cold rooms and it's not pretty.
Stick to the plain sheet and put a bit of the thread plate in at you feet if you like the look!!
Bluemoon
posted on 5/3/08 at 08:47 AM Reply With Quote
Tend to agree with using a flat Ali sheet, then a small section of you plate where you want it..
The plate you have is so pricey I would sell what you don't need should more than cover the cost of the new sheet...
Dan
<<  1    2  >>
New Topic New Reply
