Author: Subject: XE crank bolt torque
triumphdave
posted on 16/3/08 at 03:24 PM Reply With Quote
Is it really 185llb/ft +45deg,or is that a printing mistake,my torque wrench only goes upto 150llb,and I have just wrung the square off my 1/2to3/8 socket adapter (chrome vanadium lifetime guarantee)and nearly pulled the car of the axle stands.
twybrow
posted on 16/3/08 at 03:26 PM Reply With Quote
They are notoriously highly torqued. I think you will need a major impact wrench to stand a fighting chance. You might be able to budge it with a scaffold pole, but I would think and socket would break!
Richard Quinn
posted on 16/3/08 at 03:30 PM Reply With Quote
I can't recall the actual figure but it was FT! I take it you are putting it on if you are worried about the actual torque figure. I ended up taking mine to a garage to get it torqued up properly.
triumphdave
posted on 16/3/08 at 03:35 PM Reply With Quote
Yes thats right,it was put in when the engine was built but never torqued up,can see why now I wouldnt fancy trying to do it up on the bench.
TOO BADD
as per sbd torque figures plus graphite head and oil thread
MkIndy7
posted on 16/3/08 at 05:22 PM Reply With Quote
Yup it sure as hell is right!
I had to buy a 1/2" E20 socket espescially to get mine off, and even then the scaffolding pole was the only way... None of my mates air wrenches were upto it and he runs a Landrover garage!.
cidersurfer
posted on 16/3/08 at 08:08 PM Reply With Quote
My Haynes says 96lbft plus 40 to 50 degrees...
It's easy with a 4 ft scaffold pole, did it today...
[Edited on 16/3/08 by cidersurfer]
shimming solid lifters is a job for a friend...
chriscook
posted on 17/3/08 at 08:19 AM Reply With Quote
Also easy with a 750Nm torque wrench wound right up.
NS Dev
posted on 17/3/08 at 10:47 PM Reply With Quote
250NM and 50 degrees if you can get it...............
On the last one I did I had the engine solid mounted in a spaceframe, and I have made a tool which bolts to the 6 bolts on the front crank pulley and has a 4 foot long handle. I locked this against the frame and could still only get 35 degrees on the bolt with a 5 foot bar on my breaker bar tightening it up.
[Edited on 17/3/08 by NS Dev]
