wax-it
posted on 23/3/08 at 01:03 PM |
Carb Inlet - Cooling Via Exhaust Wrap
Is their a benifit to using exhaust wrap on the carb inlet?
The inlet will be "flowed" to a small extent, then painted with h-temp paint, but will I get a benifit from using the exhaust wrap?
takumi
posted on 23/3/08 at 01:25 PM |
I would say most of the inlet manifold temperature increase is conduction from the head.
You can get thermally insulating gaskets that help reduce heat transfer to inlet manifold.. other than that there's very little you can do
easily.
Reducing under bonnet temperatures generally is a good thing, having good vents in the right places, wrapped exhaust within the engine bay..
More practical approach would be a good cold air feed into your intakes, and run your engine at a slightly lower temperature than you would
normally..i.e reduce operating temp/remove your thermostat..
You could do some simple tests. Let it idle for say 20mins, measure the temp of the manifold runners..
Then make some changes to the running temp, and see if that feeds back to a slightly cooler inlet manifold...? who knows sounds like fun..
[Edited on 23-3-08 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
takumi
posted on 23/3/08 at 01:27 PM |
any changes, i suspect will be negligible in real world situations.
a thermal gasket might be the exception..
wax-it
posted on 23/3/08 at 06:59 PM |
ok, so its a slight maybe if done right, however would it also help in stopping the inlet/carb freezing?
have seen "condensation" on inlets due to cold weather.
DIY Si
posted on 23/3/08 at 08:29 PM |
The inlet freezing is generally not because of the weather. The cold merely exaggerates the existing situation. The inlet is cold/freezing due to the
air/fuel mix going through it and then cooling the inlet walls down. This can then be enough to freeze the water in the air. I have had ice on the
outside of the black painted inlet on my mini in the middle of summer before!
