Simon
posted on 30/3/08 at 01:09 AM |
Turbo boost control
Chaps,
If all goes well tomorrow and I can get Deimos running, I need to think seriously about how much boost I run, as I'll need to map to that.
Now, I like to think 1 bar is feasible, but reckon the standard Audi S4 turbos only boost to 7psi.
What's your suggestions for cheapest way of getting boost up
Simon
RazMan
posted on 30/3/08 at 05:42 AM |
1 Bar is probably fairly safe on a standard engine. The cheapest way is to use a bleed valve but the best way is to use a progressive boost controller
- either way you will need a boost gauge to check that everything is stable - I happen to have a bleed valve somewhere if you want to try it.
[Edited on 30-3-08 by RazMan]
Raz
Johnmor
posted on 30/3/08 at 09:49 AM |
Boost
My itegrale runs at around .6-.9 with a 1.2 over boost if that helps.
Thats standard from the factory.
froggy
posted on 30/3/08 at 09:57 AM |
what is the cr? how is it intercooled
stevec
posted on 30/3/08 at 09:59 AM |
I used one of These Beware of cheap imitations
though.
Steve.
NS Dev
posted on 30/3/08 at 10:03 AM |
If you are running Emerald injection then use the emerald to control the boost via a bleed valve like the amal valve off a sierra cossie or the saab
APC valve etc.
Use the ecu to map the boost, good ness me I never understand the idea of manual boost "controllers" when there's an ecu there
waiting to do the job!
Volvorsport
posted on 30/3/08 at 12:30 PM |
because using bleed or amal valves which are constantly modulating before you reach the set boost level (on cheap ecus) allows the wastegate to open
before its preset .
an inline pressure relief valve while giving a spike will not open before its set level . i used to selll some CNC machined alloy units before the
EBAY fever took over .
www.dbsmotorsport.co.uk
getting dirty under a bus
