chriscook
posted on 5/4/08 at 06:41 PM |
How quickly do you get up to oil pressure?
I started my freshly built XE just now. I got the oil pressure light out on the starter and a twitch from the gauge so went for it. When I remembered
to plug the coil pack it it started straight away.
However, when I start it it takes a couple of seconds for it to reach full oil pressure. I can't for the life of me remember how quickly it
climbed before.
It seems to be happy enough once it got warm the tappets went quiet and when I took the cam cover off for the final head bolt torqing there was plenty
of oil about up there.
The oil pump has brand new gears and the block was dipped so all the oilways should be clear.
Chris
nib1980
posted on 5/4/08 at 06:42 PM |
sounds similar to my xflow
posted on 5/4/08 at 07:18 PM |
(1) What grade oil are you using ?
(2) Are you using an OEM spec oil filter ? (oil filters differ internally some have anti-drain back valves and/or anti syphon tubes.
chriscook
posted on 5/4/08 at 07:27 PM |
oil is 15w40
it is not a standard oil ftlter it is a very short one for ground clearance reasons.
it is the same as i was using on the last engine though.
snapper
posted on 5/4/08 at 08:21 PM |
Bit of a beer moment thought this but if you start the engine and guage the time to get full pressure then kill the engine while leaving the electrics
on you should be able to see the time it takes for the pressure to drop, if it takes a while to drop then there may be a restriction in the oil feed
somewere
I eat to survive
I drink to forget
chriscook
posted on 6/4/08 at 07:56 AM |
I had a flash on inspiration as I was waking up this morning.
For the first time I used a single piece rubber sump gasket rather than the two single ones either side of the windage tray. Now the single ones have
steel inserts in them to maintain a certain thickness. The single 'c' section one does not - it you tighten the sump bolts up too much the
crank can touch the windage tray.
Now if I've done the sump bolts up too much then the oil pickup will be closer to the bottom of the sump making it harder for the pump to suck
the oil up....
If there is any restriction then it must be between the sender and the sump. If it was after the sender then I wouldn't see a problem on the
gauge. The sender is only about 1" from the pump so its unlikely to be in the block which leave the pump itself or the pickup/sump.
If it warms up a bit I'll loosen off the sump bolts and see if it improves.
C10CoryM
posted on 6/4/08 at 04:22 PM |
If it's a mechanical oil press gauge you might find that it takes a minute to bleed the air out if its capillary line is empty. If it's
been sitting, or that line was disconnected it will leak out.
Either way "a couple of seconds" sounds quick enough. Maybe you are having a bit of the fresh engine paranoia? I know it's
pretty hard not to get nervous with a new engine.
"Our watchword evermore shall be: The Maple Leaf Forever!"
chriscook
posted on 6/4/08 at 06:39 PM |
I just came back in from playing with the sump bolts and its the same. It is more than a couple of seconds but only a few...
It could be air in the sender - it is mounted horizontally. I'll whip it out tomorrow and make sure its full of oil and its not picked up any
crud in the hole while it's been lying around in a box in the garage.
Will also see how quickly the gauge reacts to a step change in sender resistance.
Chris
chriscook
posted on 7/4/08 at 09:58 PM |
Ok so this evening I took out the pressure sender and made sure there was no crud in it, changed the filter to a new one, put the sender in the
switch's hole and vice versa because it is in the pump housing itself, checked the oil filter bypass valve was ok and it didn't help.
So I checked the oil pressure relief valve and that looks ok.
Then I dropped the oil out the sump and poked a bit of 2.5mm wire in through the sump plug hole towards the pickup and it wouldn't slide under
the pickup. I only did this quickly because it was getting late i needed some dinner but I'm pretty sure that my pickup is only about 2mm from
the bottom of the sump. This sounds a bit too close to me.
There are two things it could be as the sump and pickup have been okay together before:
1) the different sump gasket is squashed more than the other style I've used
2) the pickup got bent when the previous engine expired
or both I suppose...
Looks like the sump needs to come right off - which will be a right pain now the engine is in the car.
How big a gap is normal?
triumphdave
posted on 8/4/08 at 12:18 AM |
I have got about 10-12mm clearance under mine
