Author: Subject: 06 r1
adam1985
posted on 12/4/08 at 02:14 PM Reply With Quote
06 r1
hi all what is the code for a 06 r1 engine and are these a good moter for a bec
Davey D
posted on 12/4/08 at 04:10 PM Reply With Quote
the code is : 5VY. Yes it is a good engine
adithorp
posted on 12/4/08 at 09:14 PM Reply With Quote
It's what I'm using, but beware, it has a higher final drive ratio (compared to 04-05's) so watch what diff ratio you use if its going in a sevenesque. You might not reach top revs in 6th.
Mines a Fury so not got quite the same brick like aero package.
adrian
[Edited on 12/4/08 by adithorp]
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 13/4/08 at 06:01 PM Reply With Quote
a 3.89 diff with 205/60r13 rear tyres will give you 61.9mph in 1st and 123.6mph in top which is about right for a 7.
i found when picking the diff for my fury that the real issue was 1st gear as to get a decent top end meant that 1st gear became very long, but thats mainly due to the silly high redline
