Author: Subject: Camber gain
rpmagazine
posted on 13/4/08 at 11:09 AM Reply With Quote
Camber gain
Does anyone have any data regarding production sports car suspension with regards to the amount of camber gain used?
www.racemagazine.com.au
JC
posted on 13/4/08 at 01:25 PM Reply With Quote
Can't remember the source of this - I have a printed sheet in my useful info file!!!
MX5/Miata Front Camber gain in bump 0.91 degrees per inch mean rate. Rear 0.21/0.58 degrees per inch initial/final rate
Lotus Elise Front 0.31 degrees per inch, rear 0.45 degrees per inch.
Hope this helps, will credit this to the original author when I find out who it was!
Puk
posted on 13/4/08 at 05:00 PM Reply With Quote
I'm not sure if if this is your source:
Some suspension parameters for existing sports cars:
Cymtriks on grabber
Can I ask - where are you going with the data?
Puk
[Edited on 13/4/08 by Puk]
Before you judge a guy, walk a mile in his shoes. Then when you judge him, you're a mile a way and you've nicked his shoes.
rpmagazine
posted on 13/4/08 at 10:30 PM Reply With Quote
I'm having a discussion with my suspension engineer re how much camber gain will be on Godiva. Getting base data is very important, but it is also difficult to get modern data and changes in settings from a road car to the race version in say GT3 spec.
procomp
posted on 14/4/08 at 07:18 AM Reply With Quote
Hi so many things will affect the actual amount needed. For first trying on a prototype setup it would be better to use an adjustable setup that can then be used to gain info from actual testing IMHO.
Cheers Matt
rpmagazine
posted on 14/4/08 at 11:44 AM Reply With Quote
difficult to engineer given the local regulations. It is also interdependant with FVSA lengths
