Author: Subject: Bolt on Vs Push in Diff
martylemoo
posted on 15/4/08 at 07:53 PM Reply With Quote
I am currently running a 3.62 LSD 7" bolt on diff, I would like to change my CWP for a 3.14.
Will a CWP from a push in 3.14 diff fit into a bolt on 3.62 diff?
eccsmk
posted on 15/4/08 at 08:00 PM Reply With Quote
i think they are different but im sure someone who is far wiser than me will be along fairly soon
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 15/4/08 at 08:04 PM Reply With Quote
the cwps are the same and you can swop them around the only requirement as far as i remember is that lsds need bolt on shafts.
matt_gsxr
posted on 15/4/08 at 08:26 PM Reply With Quote
the other problem will be finding a 3.14 !
Matt
Paul TigerB6
Did consider this myself but am now going for a freelander diff so didnt go too far along this so dont take this as gospel.
I believe you need a complete 3.14 diff. Leave the pinion in place and swap the crownwheel over onto the LSD unit before replacing it into the 3.14 casing. You then use the output shafts from the LSD unit as mentioned. so keep your bolt on shafts
Paul TigerB6
posted on 15/4/08 at 09:04 PM Reply With Quote
Matt
You arent kidding there!! I sold one for £350 last year!!
Liam
posted on 16/4/08 at 11:58 AM Reply With Quote
Paul's got it in one - rather than putting the 3.14 crown wheel and pinion into your LSD, you put your LSD unit into the 3.14 diff. This saves you having to re-setup the pinion to crownwheel mesh by re-shimming.
Good luck finding the 3.24 though!
Liam
