Author: Subject: Foam / Rubber Tape
The Baron
posted on 16/4/08 at 04:46 PM Reply With Quote
Foam / Rubber Tape
Does anyone know where I get some foam / rubber tape (about 2-3mm thick x 50mm ish wide) to cover up a last few sharp corners in anticipation of my SVA
B
saigonij
posted on 16/4/08 at 05:03 PM Reply With Quote
Car Builder Solutions.
www.carbuildersolutionsco.uk i think.
Mole
posted on 16/4/08 at 05:04 PM Reply With Quote
Always wanted to do this
bassett
posted on 16/4/08 at 05:11 PM Reply With Quote
If you can wait get it at a kit car show as its usually half the price and no delivery costs. Probably saved myself about £40-50 getting all the remaining stuff cheap at Detling last week. If you cant wait CBS are good.
blakep82
posted on 16/4/08 at 05:15 PM Reply With Quote
if you need it straight away, there's always halfords...
________________________
MKMike
posted on 16/4/08 at 05:32 PM Reply With Quote
If you know anyone that works at air-conditioning or refrigeration they should have or be abel to get some Armaflex tape which is similar to what you are looking for it's 1/8" thick and 2" wide. If You could also go to a refrigeration wholesaler like Dean and Wood or RSL they will have rolls of it.
or try this link:
ebay
RazMan
posted on 16/4/08 at 05:47 PM Reply With Quote
I bought a roll of foam tape from B&Q - the roofing section iirc
Raz
chris taylor
posted on 16/4/08 at 07:13 PM Reply With Quote
Foam tape
B
bought all mine from Woollies Trim on line, cheaper than CBS and the postage is more reasonable,
CT
