<<  1    2  >>
Author: Subject: 528 gallon tank???
speedyxjs
posted on 17/4/08 at 07:38 AM Reply With Quote
528 gallon tank???
Im trying to design my tank but i think im calculating it wrong.
The dimensions are 100cm x 30cm x 80cm which i work out to be 2.4 metres cubed. I used an online converter which says the volume is 528 uk gallons. Surley this isnt right?
Mr Whippy
posted on 17/4/08 at 07:42 AM Reply With Quote
oh that’s right enough, the UK gallon is about the size of a sugar cube
Mr Whippy
posted on 17/4/08 at 07:43 AM Reply With Quote
Originally posted by chris mason
3.33 x 1 x 2.66 x 6.25 = 55.36 gallons
Chris
doh! don't tell him!! sigh...
Phil.J
posted on 17/4/08 at 07:45 AM Reply With Quote
It works at at 0.24 cubic metres or 240 litres.
Thats a pretty big tank!
Paul TigerB6
posted on 17/4/08 at 07:46 AM Reply With Quote
quick calc says 240L - bit less for internal dimensions. So at current prices that would cost around £260 to fill (and contain around 240kg of fuel). You might want to go a little smaller mate!!
andyd
You've got the decimal place in the wrong place.
Cubic centimeter is the 3 dims multiplied i.e. 100x30x80 = 240000cc
Convert that into UK Gallons and that's 52.7926 or 240 litres.
Edit to say "holy crap, look at all those replies whilst I was typing!"
[Edited on 17/4/2008 by andyd]
richardlee237
posted on 17/4/08 at 07:47 AM Reply With Quote
240 litres which is equivalent to 52.4 UK galls.
Big tank, what are you running a jet engine ??
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
speedyxjs
posted on 17/4/08 at 07:52 AM Reply With Quote
No jag engine so close enough
I just wanted a rough idea but at least now i know i can go a bit smaller
I might go for about 80 litres. These jag engines arnt the most economical
Humbug
posted on 17/4/08 at 07:54 AM Reply With Quote
I know you are using a Jag engine, but even so 240 litres seems a bit on the big side
Paul TigerB6
posted on 17/4/08 at 08:14 AM Reply With Quote
240L of fuel to fill it - that would be like karting around 4 bike engines or half a BEC!!
graememk
posted on 17/4/08 at 08:30 AM Reply With Quote
i think i currently have the biggest tank at 40lts, 240 is just silly
speedyxjs
posted on 17/4/08 at 08:34 AM Reply With Quote
40 litres!!! I definatley want bigger than that
Because my engine is so heavy i want a fairly big tank to compensate a bit for that. Also i understand that alot of locostbuilders end up stopping every 100 or so miles for fill ups.
I think 70 - 80 litres will be what i go for
[Edited on 17-4-08 by speedyxjs]
graememk
posted on 17/4/08 at 08:40 AM Reply With Quote
i only just got through the brake test and axle weights at sva due to the weight of my tank full.
blakep82
posted on 17/4/08 at 09:35 AM Reply With Quote
think you may have confused your cubic meters with cubic centimeters
________________________
trikerneil
posted on 17/4/08 at 11:46 AM Reply With Quote
Build your own sports car.
And fill it up for £250
ACE Cafe - Just say No.
mcerd1
posted on 17/4/08 at 12:10 PM Reply With Quote
what they all said ^^^
what size tanks do the jags normally have ???
1 gal (UK/ imperial) = 4.564 l
2 gal (US) = 3.785 l
JohnN
posted on 17/4/08 at 12:41 PM Reply With Quote
Are you sure 1m x 0.8m x 0.3m, that's either unfeasibly tall, or unfeasibly big in plan, neither would fit in the rear space of a seven.
Sure it isn't 0.1m x 0.8m x 0.3m
Which is 0.024m3, ie 24 litres? ie 5.2 gallons?
[Edited on 17/4/08 by JohnN]
stevebubs
posted on 17/4/08 at 12:55 PM Reply With Quote
Cruising... I get about 300 miles on my 50litre tank....blatting....a lot less...
2 litre zetec with Gixxer 750 Throttle Bodies
awinter
posted on 17/4/08 at 01:11 PM Reply With Quote
tank size
my 4957cc V8 928 weighs 1650kilos and has an 80litre tank, cruising at 70mph it will do 400 miles on a tank.
The sylva striker has a 900cc bike engine in it and a 24litre tank and will do 170 miles on a tank @ 70mph
Fitting a 80l tank to your car is overkill. 40l max.
Yes if you blat it mpg is crap but take a jerry can or 2 it'll be better in the long term.
Ta
Allan
RazMan
posted on 17/4/08 at 01:51 PM Reply With Quote
I went for twin 25L tanks to get better balance while acheiving a realistic range - about 300 miles of cruising with my V6.
Watch out for sloshing too - it can really throw some weight around and upset things if not adequately baffled. You could also consider foam filling.
Raz
speedyxjs
posted on 17/4/08 at 03:28 PM Reply With Quote
80 litres and lasts about 3-400 miles.
My chassis isnt a standard locost chassis. Its quite a bit bigger
Maybe 80 litres is too much
I want more than 40 litres because that would have about half the range of my tin top.
[Edited on 18-4-08 by speedyxjs]
D Beddows
posted on 17/4/08 at 04:00 PM Reply With Quote
Just a thought but have you ever driven over 200 miles in a 7 (let alone 400 ) without stopping???? It's not quite the same thing as sitting in a Jag and doing it and I think you'll find you wont fancy doing it that often.........
clairetoo
posted on 17/4/08 at 04:34 PM Reply With Quote
Its cuz I is blond , innit
Claire xx
Will weld for food......
speedyxjs
posted on 17/4/08 at 05:16 PM Reply With Quote
good point Didnt think of that
JohnN
posted on 17/4/08 at 06:06 PM Reply With Quote
"JohnN - My chassis isnt a standard locost chassis. Its quite a bit bigger"
What is the height of your tank then? Your chassis doesn't have a rear at the moment from your archive photos, but it looks like it'll need a huge one then. Either 1m or 0.8m is way higher than the vertical space available above the differential. have you actually made this tank(er) yet then?
<<  1    2  >>
