Author: Subject: bearing wanted
graememk
posted on 23/4/08 at 08:43 PM Reply With Quote
bearing wanted
not sure how to explain this, my steering has an extra uj and it has a rubber bearing in a metal plate, its perrished and i want to replace it with a bearing that i can bolt to a flat plate must be 15mm can anyone help me ?
owelly
posted on 23/4/08 at 08:44 PM Reply With Quote
BSL Brammer can help you!!
http://www.ppcmag.co.uk
owelly
graememk
posted on 23/4/08 at 08:45 PM Reply With Quote
who, is it a person or a company ?
owelly
posted on 23/4/08 at 08:49 PM Reply With Quote
It's a company. You can google them but the webby isn't much good for finding things! There's a guy one here who works for them but I forget his (and my) name!
owelly
posted on 23/4/08 at 08:59 PM Reply With Quote
http://www.bsl.co.uk/home.shtml
big_wasa
posted on 23/4/08 at 09:43 PM Reply With Quote
Do you mean this bit ?
graememk
posted on 23/4/08 at 09:49 PM Reply With Quote
nope.
the shaft goes through a plate which has a rubber sleave acting as a bearing but its split, i want to replace it with a rose joint style bearing that will bolt to a flat plate insted of a threded bar
daviep
posted on 23/4/08 at 10:05 PM Reply With Quote
Something like THIS?
daviep
posted on 23/4/08 at 10:09 PM Reply With Quote
Or possibly THIS?
graememk
posted on 23/4/08 at 10:12 PM Reply With Quote
Originally posted by daviep
Or possibly THIS?
thats the kiddy "daviep" but the center must be able to pivit like a rose bearing as the plate it fastends to is at 90degs and the steering shaft comes through at an angle.
GazzaP
posted on 24/4/08 at 07:55 AM Reply With Quote
Hiya
I work for Brammer! The bearing that is above my post is identified as a self lube bearing. I run one of these where the steering coloumn goes through the bulke head just above the pedal box on a slight angle and it work's great and gives the shaft more stability. I'll try and get a photo loaded today at some point as i'm on holiday this week. There are avarious different qualities of bearing the one shown above is a japanese item which are ok! the best are the RHP/NSK items.
regards
Gary
www.gmpmotorsport.co.uk
posted on 24/4/08 at 05:41 PM Reply With Quote
IIRC I have seen a post showing how to install the type of bearing you want. If it wasn't here it may have been on the Robin Hood owners site? It may have given the part number and supplier of the bearing if it helps.
eccsmk
posted on 24/4/08 at 06:44 PM Reply With Quote
you could try imperial bearings in boston
think they are nex door to H&L on marsh lane
