Author: Subject: needed - MSnS extra map Pinto/TBs
DaveFJ
posted on 25/4/08 at 03:20 PM Reply With Quote
as per the title
looking for a base map that is at least similar to my setup...
Pinto 2.1 with GSXR 750 TBs...
Anyone seen one lying around looking unloved?
cheers
Dave
yamapinto
posted on 25/4/08 at 04:26 PM Reply With Quote
base map
I am running a 2.1 pinto with yamaha TB but with twin injectors per cylinder we have quite a good map but i cannot send it to you (i dont know how im thick) my son will be home from work soon i will get him to send it when he comes in
DaveFJ
posted on 25/4/08 at 04:27 PM Reply With Quote
that would be great! will give me somewhere to start at least
cheers
Dave
yamapinto
posted on 25/4/08 at 05:08 PM Reply With Quote
I've attatched the map were running at the moment, the basics are there and its running on the rich side for safety.
you'll need to switch off the staged injection in "advanced" then "staged injection"
We've also got switchable ignition maps and the 2nd one on there is by far the best but it may require the whole of the table retarding by 4 degrees or it maybe ok, just a warning.
You may also have to alter the req fuel to suit your injector flow rates, our maps set for 160cc/min injectors.
Just have a play and see what it'll do, it should atleast get it started.
