Author: Subject: Cold air sucker
Triton
posted on 29/4/08 at 09:14 PM Reply With Quote
Cold air sucker
Airbox that fits across a bank of 4 bike carbs as well as webers..will need flexi pipe to allow airfilter to be mounted where it can suck cold air...down in the nosecone somewhere I guess
£65.00 as fiddly blighters to make
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
eccsmk
posted on 29/4/08 at 09:15 PM Reply With Quote
do you have a piccy??????????????
Triton
posted on 29/4/08 at 09:25 PM Reply With Quote
Couldn't find the new picture so nicked this from my archive.
Triton
posted on 29/4/08 at 09:26 PM Reply With Quote
Umm bit mucky but you get the gist ...
Mark
worX
posted on 29/4/08 at 09:39 PM Reply With Quote
What size is the inlet Mark?
eccsmk
posted on 29/4/08 at 09:44 PM Reply With Quote
cheers for that
thats yet another reason to spend money
doh
Triton
posted on 29/4/08 at 10:28 PM Reply With Quote
Inlet will take 2" flexi pipe...but will check in the morning and make sure I didn't dream that up!!!
Mark
triumphdave
posted on 30/4/08 at 06:46 AM Reply With Quote
Any chance we could have some overall sizes,is the base plate included?
Triton
posted on 30/4/08 at 07:32 AM Reply With Quote
Will take some measurements and post them later today...it has a base as part of the box so can be made to fit ....may need to put the "locost" head on but nowt impossible
Mark
Mr Whippy
posted on 30/4/08 at 07:34 AM Reply With Quote
I'm sure I've seen something like that in hospitals but they have another propose there
Kriss
posted on 30/4/08 at 08:40 AM Reply With Quote
Looks great. Take it this would fit a '03 R1 MK Indy no problems? So do you just need to run a cold air feed 2 inch and attach a cone filter in the nose cone?
procomp
posted on 30/4/08 at 08:43 AM Reply With Quote
Hi just remeber if fitting one of those type of air boxes you will need to be re jetting your carb setup too.
cheers Matt
Triton
posted on 30/4/08 at 10:33 PM Reply With Quote
Better they suck cold air than stuffy old hot air under that 'glass or ali bonnet.
Re jetting will most certainly be needed and would say a rolling road session would be the best bet to get the most out of what you have.
Cone or sock type doodah down in the nose where it can suck cooler fresher air.
Mark
Roman
posted on 29/7/08 at 03:02 PM Reply With Quote
3 inches?
Are you able to offer 1 of these with a 3" inlet?
Do you have any dimensions and better pictures?
