New Topic New Reply
Author: Subject: Leaking brake master cylinder
R16HTD
posted on 2/5/08 at 01:56 PM Reply With Quote
I have now had 2 sierra master cylinders and they have both leaked from the push rod end. I cannot source new seal kits does any have the same problem or know how to fix it?
thanks
Bluemoon
posted on 2/5/08 at 01:59 PM Reply With Quote
Have you fitted a dust boot? Might be grit getting in and soring the cylinder??
dan
R16HTD
posted on 2/5/08 at 02:01 PM Reply With Quote
I have not had on the road yet to get dust in. They have both leaked straight after bleeding the brakes.
posted on 2/5/08 at 02:07 PM Reply With Quote
it makes you wonder, doesn;t it?
are they made in China by one armed pandas?
are you doing something wrong or are they both faulty.
obvously they should not leak - definitely not getting fluid dribbing from somewhere else that makes it appear to come from the piston seal end?
is it possible that the push rod is at a bad angle or not central so that it tilts the piston? (don't see how it can but ...)
have you taken them apart to see if there is anything obviousy wrong?
... so it is a bit of a mystery.
[Edited on 2/5/08 by 02GF74]
l0c0st
posted on 2/5/08 at 04:55 PM Reply With Quote
I've had the same problem. The original one from the donor leaked, then another secondhand one from e-bay leaked. I think the rubber seals just perish if they aren't used for while.
I've tried to find new seals but can't, although you can still get new m/c so they must be out there somewhere.
Dom
snapper
posted on 2/5/08 at 06:29 PM Reply With Quote
3 second hand and they all leaked, ended up paying £105 New Old stock on ebay.
I eat to survive
I drink to forget
posted on 2/5/08 at 06:52 PM Reply With Quote
Might be worth trying Past Parts in Bury St Edmonds. They helped me when I wanted an old Alfa master cylinder repaired when no one else could . Had been quoted £600 plus vat by one guy for a new old stock . Past Parts charged a total of £90 to sleeve and reseal with new pistons.
nasty-bob
posted on 2/5/08 at 07:38 PM Reply With Quote
Were they new or secondhand?
If secondhand, when bleeding you should not depress the pedal futher than it would go in normal use as it damages the seals.
If new, then ignore.
Schrodinger
posted on 2/5/08 at 09:05 PM Reply With Quote
Try LSUK (used to be Lucas) IIRC they made one of the master cylinders in the Sierra.
Look here for your nearest branch
http://www.lsuk.co.uk/branch_locator/england.html
[Edited on 2/5/08 by Schrodinger]
Keith
Aviemore
robinj66
posted on 2/5/08 at 09:29 PM Reply With Quote
try Eg, here
ht tp://cgi.ebay.co.uk/FORD-SIERRA-BRAKE-MASTER-CYLINDER-KIT_W0QQitemZ330230838006QQihZ014QQcategoryZ27377QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
mark chandler
posted on 2/5/08 at 11:01 PM Reply With Quote
I used a master cylinder off a range rover, £60 brand new, now on Ebay for only £45.
You get three outlets, one for the rear, two for the front and a fluid level cap. Rescued attachment 7602_1.jpeg
Alex B
posted on 5/5/08 at 07:14 PM Reply With Quote
Is that a pattern part?
Alex
Much work still remains to be done before I can announce my total failure to make any progress
New Topic New Reply
