Author: Subject: My new, curved windscreen
Mave
posted on 3/5/08 at 06:43 PM Reply With Quote
Today I had my first drive with my new windscreen in place. As you can see, it has a slight curvature in it. I'm really happy with the result, but it was A LOT of work, and wouldn't do it again.
speedyxjs
posted on 3/5/08 at 06:52 PM Reply With Quote
Very nice
Where did you get that windscreen surround from?
Mr Whippy
posted on 3/5/08 at 07:09 PM Reply With Quote
very fancy car
Griffo
posted on 3/5/08 at 07:47 PM Reply With Quote
Very very nice.
EDIT: out of interest what is it made out of and how did you go bout curving it?
[Edited on 3/5/08 by Griffo]
Mave
posted on 3/5/08 at 08:20 PM Reply With Quote
It's laminated glass. Custom made. I supplied them the flat pattern, and the radius of curvature I wanted, and they made it. It was made by a company called Autoglas D&K here in Holland (link)
I made the carbon cover myself, as well as the actual windscreen frame. The basis is steel tubing, cut and welded a zillion times to get the complex curvature..... The frame has two legs that extend through the scuttle and bolt to the chassis.
Mr Whippy
posted on 3/5/08 at 08:49 PM Reply With Quote
wow there's dedication
RazMan
posted on 4/5/08 at 07:58 AM Reply With Quote
Nice job! It's surprising what such a subtle curve does for the looks of the car.
Just a little bit of constructive criticism - the CF surround look a little heavy. Can you trim a little bit off it to make it thinner?
All IMHO of course
Raz
dr-fastlane
posted on 4/5/08 at 09:26 AM Reply With Quote
Hey Marcel,
That looks great, i like the donkey look of it. One other question, can you give me the hella number of the front blinkers?
Roy.
[Edited on 4/5/08 by dr-fastlane]
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
Mave
posted on 5/5/08 at 04:29 PM Reply With Quote
Nah, I can't trim anything off, and neither do I want to. I see what you mean, but to me it makes the car look a bit more modern, and that's how I like it.
@Roy; the number on the glass is 152 128. I don't know if it's of any help. But is just a regular Hella light; normally it has three mounting tabs around the circumference, but I cut them off.
dr-fastlane
posted on 5/5/08 at 08:04 PM Reply With Quote
Big thanks for that one
