Author: Subject: Respacing carbs
dave1888
posted on 13/5/08 at 09:04 PM Reply With Quote
Respacing carbs
I have respaced a new set of carbs to match the bogg bros manifold, only thing i have left to do is extend the little butterfly lever thing between the outside carbs. Can i get piece of metal tig welded or should i atempt making some new ones.
jacko
posted on 13/5/08 at 09:10 PM Reply With Quote
I have just extended some for Tim Windmill on here i just gas welded extentions on the original lugs
Jacko
posted on 13/5/08 at 09:21 PM Reply With Quote
I MIG-welded mine - I just clamped the pieces to a steel block and joined them up. "Before" on the right, "after" on the left (not completely tidied up when this piccy was taken)
[Edited on 13/5/08 by David Jenkins]
posted on 14/5/08 at 08:26 AM Reply With Quote
that looks like a piece of 1-2 mm steel - shouldn't be that hard to make a new one, the oval hole would be the hardest to drill
