Mr Whippy
posted on 19/5/08 at 11:53 AM |
Cortina mk4 steering lock & key
ok I'll admit this was my fault, after the Falcon got bashed up (a few years ago) and took it back home, I threw he key into the field in a
temper oops
erm I can't find in it, may have sunk in the mud or the cows might have eaten it
So like, I need a new lock and key...
any one got one going spare???
Plus any ideas about getting the old lock out without destroying my lovely column?? or is it drill time
[Edited on 19/5/08 by Mr Whippy]
MKMike
posted on 19/5/08 at 03:09 PM |
I'm looking for one too, the barrel is the same as the mk1 sierra (which I'm using the column of for my Indy), I cannot find one anywhere.
I had to drill the centre of the barrel with I think about an 8mm bit then turn it with a screwdriver to the no 1 position and there is a pin a the
side that you push in. If you have a similar old ford key that is worn, it will open the lock with a bit of wobbling around and the like, once you
get it out you can get a proper key cut using the number on the side of the barrell.
