Author: Subject: Mini Cooper S bonnet vent.
nib1980
posted on 21/5/08 at 06:49 PM Reply With Quote
Hi
anybody on here got a mini cooper S, I want a few dimensions of the Bonnet scoop.
I've had an Idea
Many thanks
Neil
jos
posted on 21/5/08 at 06:59 PM Reply With Quote
dont have one but know somebody who does and am seeing them tomorrow if you tell me what you want to measure
nib1980
posted on 21/5/08 at 07:06 PM Reply With Quote
basically width, depth and height, and if possible the install angle (if you knwo what I mean)
MANY thanks!!
Nib
jos
posted on 21/5/08 at 07:13 PM Reply With Quote
will have a look tomorrow
TGR-ECOSSE
posted on 21/5/08 at 10:21 PM Reply With Quote
The Mini Cooper S Does not have a bonnet scoop
Did you mean a BMW? If so sorry i don't have one i only do real Minis
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/5/08 at 11:01 AM Reply With Quote
If you do get one, this one is pretty smart (though maybe exspensive!)
LINK
Unfortunately this guy got a bit slated for this attempt
LINK
PS, sorry can't help with dimensions, i tried to quickly google it..
jos
posted on 23/5/08 at 07:17 AM Reply With Quote
Ok,
Looking from the front the top of open part of the vent before it starts to curve is 360mm wide. The middle is 385 wide (clear) and the bottom again before curve is 300mm wide.
Viewed from above the leading edge to the front of the top IYSWIM is 90mm and the moulding is 135mm O/A with the trailing edge (rear of the top) is 450mm O/A
HTH
nib1980
posted on 23/5/08 at 07:23 AM Reply With Quote
Perfect !
Many thanks
Neil
