Author: Subject: Bike engine choices
Jezzer99
posted on 21/5/08 at 08:35 PM Reply With Quote
Bike engine choices
I'm just starting a Haynes Roadster. Curious on what bike engine options would be good - any ideas?
matt.c
posted on 21/5/08 at 08:47 PM Reply With Quote
ZX9
ZX12
R1
Blade
Busa
The list goes on.......
Depends on how deep your pockets are?
[Edited on 21/5/08 by matt.c]
posted on 21/5/08 at 08:59 PM Reply With Quote
ST1100 or ST1300
Well what else would I say
Jezzer99
posted on 21/5/08 at 09:03 PM Reply With Quote
My pockets are very very shallow How much am I talking about for each option??
Dangle_kt
posted on 21/5/08 at 09:11 PM Reply With Quote
search is your friend mate - this forum has a very good search function, its worth using.
matt.c
posted on 21/5/08 at 09:13 PM Reply With Quote
If your pockets are shallow then prob best will be the zx9/blade at around £700 for the engine.
twybrow
posted on 21/5/08 at 09:18 PM Reply With Quote
Triumph Daytona!
thegasmen
posted on 21/5/08 at 10:30 PM Reply With Quote
engine choice
What about honda blackbird 1100
for power per pound you wont beat it for that its an engine that is overlooked a lot of the time and consiquently can be bought for a song its sweet as a nut in my dax rush
beppesignori
Contributor
Posts 82
Registered 7/8/06
Member Is Offline
Photo Archive Go!
Building: MK Indy Sold. Contemplating V8 midi scratch build
posted on 21/5/08 at 11:50 PM Reply With Quote
I chose the CBR 1000 RR for mine with some regrets. I am sure once it runs I will be happy again, but it will be after considerable hurdles had to be overcome.
The sump is very deep, and unless you want a centre of gravity of a landrover, you need a new shallower sump...500£..
Secondary injectors above the inlet ports mean you cant just stick a pipercross across the TB's, as the injectors and the airflow across them are very sensitive to change. It also means you cant lower the highest point of the engine very easily. The fuelrail of mine sticks out through the bonnet bulge.
Oval outlet ports make the manufacture of an exhaust manifold more complicated.
Other than that, I have heard that it is a very powerful machine, and has done very well in racing.
sucksqueezebangblow
posted on 22/5/08 at 08:23 AM Reply With Quote
Strech to the Hayabusa if you can, 180BHP as standard. V popular with drag racers hense shedloads of aftermarket parts and can be taken up to 500BHP. Slight downside is price about £2300 - £2500 but you could be lucky if you pick up a complete bike for a good price and sell off the unwanted parts.
eznfrank
posted on 22/5/08 at 08:29 AM Reply With Quote
or a ZX12 will pop out roughly the same power as above but will cost you about £1k less and is less likely to need a dry sump (depending on your intended use)
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/5/08 at 11:11 AM Reply With Quote
This guy seems to have a lot of bike engines available!? I've no experience with him but others may???
LINK
[Edited on 22/5/08 by iscmatt]
mac1
posted on 22/5/08 at 12:38 PM Reply With Quote
you want malc yorkshire engines 07960011585
best ever supplier by far
eznfrank
posted on 22/5/08 at 09:09 PM Reply With Quote
Yeah, as above, Malc's your man, he'll offer you loads of advice/stats etc and he has plenty to choose from. Not the cheapest around but only sells low mileage fairly clean blocks. He is a member but not seen him on here for a while though???
aka Keith
posted on 23/5/08 at 09:27 AM Reply With Quote
That ebay seller is listed as Yorshire Engines - which is Malc is it not?
