Author: Subject: So what about Zetecs?
Jezzer99
posted on 21/5/08 at 09:06 PM Reply With Quote
In contrast to bike engines in my other post, what about Zetecs - they seem cheap but I understand they're quite difficult to get running at a reasonable cost - any views?
madteg
posted on 21/5/08 at 09:19 PM Reply With Quote
zetec
The cheepest way is to use bike carbs and megajolt ignition.
megajolt 70 quid.
carbs 65 quid.
inlet manifold 150 quid or make your own.
make exhaust manifold and down pipes.
once you have got all bits you can pick up engine for 100 quid if needed.
big_wasa
posted on 21/5/08 at 09:27 PM Reply With Quote
The zetec can be done as cheap or as dear as you wish
hillbillyracer
posted on 21/5/08 at 10:18 PM Reply With Quote
It would seem to be quite possible to get a Zetec running on it's own management out of the donor car, I've seen cars with it done but I dont know how well they went.
Surely if the whole system is used (loom, sensors, ECU, immobilizer unit, key reader & key etc) then the engine wont "know" that it's no longer attached to a Mondeo/Escort?
The only thing that I hear needs sorted is a speed signal but surely it would'nt be too hard to mount a sensor on the prop?
I'm certainly going to have a go at it unless I have a go at Megasquirt.
zetec
posted on 22/5/08 at 05:00 AM Reply With Quote
If you look at what you would spend on other engines in total they is very little difference. If you look at a Pinto for example, you will more than likely need to rebuild it- poss fit twin webers-have to have an exhaust made up just as with the zetec and you will if lucky have 140 bhp. With a zetec you can, unless you are unlucky, just fit it without need to rebuild, sort out an ecu and fit TBs or carbs and 160bhp. If you spend out on an ecu and fancy a change of engine then you wont have this cost again. Fit a modern engine with injection and it will be reliable, powerful and run smooth from the first turn of the key! And if you do blow it up just nip down the breakers and get another for next to nothing.
Mave
posted on 22/5/08 at 06:31 AM Reply With Quote
I don't understand why people still think it's not possible to use the original ECU to run the Zetec. I'm using the original inlet manifold and ECU, and it's completely reliable. The wiring wasn't that difficult either (and I'm a complete nooby when it comes to electronics). And there's no cheaper and easier way to run the Zetec. I'm running the silver-top 2.0, and in this standard trim it gives me a sub 6 seconds 0-60 time.
It might very well be possible that the blacktop Zetec is harder to run on its factory ECU, as that has some immobiliser-thingies on board, that the silver top hasn't.
Werner Van Loock
posted on 22/5/08 at 08:00 AM Reply With Quote
Some silvertops have immobilizer, depending on the model they were in.
http://www.clubstylus.be
MKMike
posted on 22/5/08 at 08:36 AM Reply With Quote
Quote:
"I don't understand why people still think it's not possible to use the original ECU to run the Zetec. I'm using the original inlet manifold and ECU, and it's completely reliable. "
Mave, I notice that you are from the Netherlands so your car is probably LHD which means that you don't have the problem with trying to get the steering shaft past the very bulky inlet manifold.
[Edited on 22/5/08 by MKMike]
posted on 22/5/08 at 09:10 AM Reply With Quote
Any mid 94' onwards Mondeo or any Focus will have a version of the PATS immobiliser. The Mk5 Escorts were also immobilised IIRC.
[Edited on 22/5/08 by MikeRJ]
whitestu
posted on 22/5/08 at 10:34 AM Reply With Quote
My Zetec installation [conversion from CVH] with bike carbs and megajolt cost about about £200 all in, so it can be done very cheaply. This doesn't include the exhaust though as my CVH one fitted with a bit of modification.
Stu
saigonij
posted on 22/5/08 at 10:57 AM Reply With Quote
I have used the ECU and wiring out of my donor escort ( it did not have PATS ), and i used a mondeo plastic inlet manifold.
simple, easy to wire in, cheap as chips.
smooth idle, no messing with MAPS or trying to get the car started for the first time,
starts first time, every time.
Jezzer99
posted on 22/5/08 at 06:09 PM Reply With Quote
Really interested in some more details about the projects using the existing ECU. Is there a definitive list of what had the immobiliser system on? Failing that, megajolt looks interesting but would like to know more about how to do it that way. What's the best gearbox to mate the Zetec to?
saigonij
posted on 22/5/08 at 06:15 PM Reply With Quote
Escorts from 1992 - 1995 ( MK5 ) did not have an immobiliser, same for the orion.
I used this ECU and the wiring loom - it results in about 5 wires that you connect up ( i have a document that i can email you ).
I used the mondeo plastic manifold as its very low profile, and clears the steering column - i had my velocity chassis made with the drivers side triangulation chassis member moved back by 4cm to allow clearence for the manifold. I also had to strip the manifold loom on the silver over-the-top manifold and fit it to the mondeo manifold ( this is because the connectors have different pin-outs ).
thats it. i used the escort, cause its easier than the mondeo - and it has a seperate EDIS unit, so should you want to go down the mega-squirt route you alrady have it.
easy :-)
Jezzer99
posted on 22/5/08 at 07:31 PM Reply With Quote
So do you think if you had a Zetec with immobiliser etc, if you had the key/loom/ECU etc. that it would work - I'm with one of the earlier posts that I can see why it wouldn't???
mr henderson
posted on 23/5/08 at 07:24 AM Reply With Quote
I am very interested in this subject too. The last Mondeo I started to dismantle (I had to abandon that particular project for external reasons) it was my intention to use all the standard ecu and injection system.
It did have the PATS immobilisers but I figured that if I kept all that stuff I would be OK.
The problem turned out to be that the wires from the key surround receiver disappeared into the loom, which is about 20m thick! and at some hidden point inside the loom change colour in an effort to frustrate car thieves (and locost builders).
Next time I will either decide from the outset to use an aftermarket ecu or otherwise I will have to find a way of removing the loom intact by cutting through the metalwork in various places to release the loom without cutting it.
I think it would be extremely worthwhile to find a way of using the existing ECU, and as donors that don't have an immobiliser are getting older then addressing that problem becomes more important.
The donor I was working on was an MOT failure (brake pipe corrosion) 2.5 ghia. 170 bhp and some nice alloy wheels etc etc for £500. I had driven the car and the engine was perfect. 170 bhp and 4 good alloys and tyres for £500. That's sufficiently Locost for me, just need to deasl with the PATS problem.
trogdor
posted on 23/5/08 at 08:18 AM Reply With Quote
later engines will work with the earilier looms apparently, i definatly read that somewhere. Not sure how well tho.
If anyone is interested i am trying to get rid of a escort wiring loom complete with ECU suitable for a silvertop zetec. Possibly later ones as well.
Jezzer99
posted on 24/5/08 at 07:33 AM Reply With Quote
Whitestu - would be very interested in know more about your installation - do you have a web site or can you tell me more off line?
Cheers.
